Results 1 to 2 of 2
Thread: Grouping
    Jan 2004
    Oudenbosch, The Netherlands
    33
    Question Grouping
    This is probably a simple question. I'd like to group my objects but I don't know how. For example, if I put 3 boxes into my scene and export it to a *.OBJ file, the 3 boxes are exported as one big object. How to sepperate them? And how to select on group in Modeler?
    I tried Display->Grouping->Change part name on a selection of polygons but in the OBJ file, it's still 1 object.
    Greetings,
    Rick
    I assume that you're exporting from modeler, not Layout, so it's not actually a 'scene', it's an object - Modeler's space is like 'object mode' in other programs, all the geometry you put on one layer will be in the same object.
    If you're trying to export a model in a way that has some .obj 'layers', I don't think this is possible, you probably have to export each object as a separate model.
    Confirmed -
