Thread: LW[8] Transparency Bug
    Netherlands
    5,560
    The message which I put here was about a user error. So the main reason for posting is gone. However there is the pixel blending problem, if anyone can shed some light on it...
    There are a few things going wrong here:
    -OpenGL weirdness
    -When in any of the surfaces numberer 1 to 5 in the transparency channel 'Pixel blending' is selected the whole transparency goed heywire. This is also the case in 7.5c. If this is not a bug can someone explain me why this occurs?
    Netherlands
    5,560
    Here's the 7.5c image:
    Netherlands
    5,560
    And here is the scene file, objects and maps.
    Attached Files Attached Files
    Netherlands
    5,560
    [edit]
    hmm can you explain what the problem is a little more? and what effect you are trying to get?
    Firstly wouldn't it be alot easier to use lightwaves gradients instead of an image?
    Netherlands
    5,560
    I find the gradients for just mapping in a certain direction rather cumbersome. And they dont work for backdrop either, so I have a gradient loaded anyway.
    The problem is, when you put an image in the transparency layer, and set the edge condition to 'edge' the Pixel blending will screw up the surface.
