Results 1 to 2 of 2
Thread: Need help on making text move in front
    hi.i'm currently doing my 1st project with lightwave on making a text move in front.The scenes is as describe below
    I tried to make a 3d text move in front by creating key movement on the camera .At 1st it have no problems but when i tried to make the text stops half way for a few seconds then keep on moving in front a problem occurs.The problem is the object will move backwards for a while then only it continues.How can i solve this problem??Am i doing it the right way??pls help me.thank you.
    Jan 2004
    TX, USA
    51
    I'm not sure I understand your problem, but I believe you are talking about when you move the camera and make keyframes, the camera will make a smooth motion between the keyframes.
    Try this:
    1. Select the camera and open the Graph Editor.
    2. Select all the Keyframes.
    3. Change the Incoming Curve to Linear.
