Results 1 to 2 of 2
Thread: Subpatch solution
    Registered User Mat's Avatar
    Apr 2004
    Dover Tasmania
    263
    Smile Subpatch solution
    If you want to get a realy smooth result you can always use
    a subpatch object
    First creat a disk then use the bevel tool holding down ctrl
    Bevel the circle inwards and then delete the centre polygon
    then press tab to turn it into a subpatch
    and then all you have to do is to use the size strectch tool
    I sugest to first use the the size stretch on the whole object
    and then adjust the centre points
    once you have your object in layout you can increase the
    detail in the object properties panel setting the render subpatch
    division level higher
    hope this helps
    You can always use the cone tool then merge the tris into quads and delete the base polygon. It's pretty much then same thing you suggest but all the centre points are merged.
    It's a pity that someone can't make the "lost in time" center triple plugin saving alot of modelling time for this technique.
    Also, there's a plugin called converge points, which is useful for aligning points for stuff like this.
    BTW, welcome to the forum.
    Revanto
    I'm a Mega 3D dude!!!
    Check out my friend's OLD Youtube tutorials
    Mix Mash's tutes
