Thread: texuristaion
    Nov 2003
    sdfsdf
    11
    Arrow texuristaion
    Hy, im ok at modeling but my texturing lets it down. I can only make the textures look ok around one axis. how do u get them to perfectly fit around an object? and how do you make your textures?
    May 2003
    UK
    116
    Wink
    UV map everything.... !! Make textures? - Photoshop.
    Newbie Member DeltaF86's Avatar
    Dec 2003
    Topeka, KS
    30
    yeah, I'm in the same boat. UV isn't easy to do...at least with Inspire!
    *waits patiently for LW8*
    Inspire 3D
    *for now!*
    BWAHAHAHAHAA!
    Partially Baked blabberlicious's Avatar
    Jun 2003
    London, England
    678
    Take a look at Robin Wood's excellent series on UV mapping
    HERE
    Good luck!
    Steve Williams | d i g f r e a k | UK
    Mac: Dual 2.5GHZ G5, 2g Ram, ATi 128 OSX 10.3.7
    PC: AMD 64 X2 Dual Core +3800, Quadro FX 1300, 2 GiG Ram
    I used to really hate UV mapping, but I've grown quite fond of it lately. (The trick is to apply the mapping as you go, as opposed to waiting until the end...) If you use it like you'd use projection mapping, establishing the co-ordinates isn't so bad. Create a box that's bigger than your whole object. Then select all 6 faces of it while selecting all the polygons of a particular Axis you're on, and assign the UV map. Once you get into the groove of doing it, it goes by pretty quickly.
    Go TEAM VAD!! \/
