Results 1 to 12 of 12
Thread: Newtek...Where are they?
    state of confusion
    6,973
    I see some stuff for expressions on your tut site,
    specificaly this :
    MBLightWave 3D Expressions Part 1: Nuts And Bolts
    Are the other parts somewhere else (not on that page and no links to other pages there).
    I need to learn this and that first part was basic enough for even me. BUT I need more!!!
    Skype...lost_in_3d_space
    Sager
    I7-4800 OC'd to 3.3 GHz
    12G 1600mhz mem
    256 gigs raided SSD drive
    Seeing red Kurtis's Avatar
    Feb 2004
    Bottom of the bag
    1,494
    I can't speak for anything currently being developed for our site, but you might want to try LightWave Tutorials on the Web: Expressions/Sliders/Motion Modifiers
    Kurtis Harris - NewTek 3D Marketing
    All statements to the effect of this parrot is still a going concern are from now on inoperative. This is an ex-parrot.
    state of confusion
    6,973
    K, Thanks
    Looking for something that should be really simple to do (cept for me)
    Kinda like ;
    If bone 1 rotates 90 degrees then bone 2 rotates half of 1s degrees.
    But I have brain implosion when it comes to this stuff.
    Sager
    12G 1600mhz mem
    on the second bone you could do this expression:
    [firstBone.Rotation.H] / 2
    state of confusion
    6,973
    See ??
    That's why your name says 'Super Genius' and mine only says 'Member'
    So if I read this correctly;
    I need to put an expression on what I want to have result to be and *not* the driving bone?
    And I can change the H to another channel? Or direction?
    And I can do this even if the bones aren't even close in the skeletal system?
    Now...where does it go on the second bone?
    I mean where do I put this info?
    Same channel?
    Or can I do another channel to rotate second bone 90 degrees on Y and half the amout that bone 1 moves?
    Hmmm, gotta set up a 2 bone scene and play with this.
    Sager
    12G 1600mhz mem
    right.
    Yup.
    Right again.
    Now...where does it go on the second bone? I mean where do I put this info? Same channel? Or can I do another channel to rotate second bone 90 degrees on Y and half the amout that bone 1 moves?
    You put the expression on the channel(s) you want to affect. Getting 90 degrees plus half the rotation of bone 1 looks as you would expect:
    90 + [firstBone.Rotation.H] / 2
    Or, you can get the keyframed value plus half the rotation of bone 1:
    Value + [firstBone.Rotation.H] / 2
    as they say in gaming: GL. HF.
    state of confusion
    6,973
    Well, no matter how I try to put this stuff, I get the same errors.
    Blue bone is bone01
    Yellow is bone02
    I highlighted the channel on bone02 that I want to effect
    then I wrote the expression (making sure that caps and everything was exact)
    and I get the error in pic.
    ARRGGGG!
    Sager
    12G 1600mhz mem
    i'm not an expert on this stuff, but i think the bone is only accessible via the object it belongs to so you might have to do something like:
    [myObject.Bone01.Rotation.H]
    state of confusion
    6,973
    That was your example
    This is mine
    [Bone01.Rotation.H] /2
    except for name of bone it *looks* the same to me
    Yet when I rotate bone 1 nothing happens to bone 2, no matter which way I rotate it (figuring I might have got the wrong channel)
    It's ONLY 2 bones!!!!
    what is my brain NOT grasping???
    Sager
    12G 1600mhz mem
    Kansas
    1,614
    Prospector:
    Just curious, have you tried Amelie Visual expression editor. It makes such as this much easier, for only $49.
    You need to prepend the name of the object that the bone belongs to:
    [objectName.boneName.Rotation.H]
    that should get rid of the error.
    state of confusion
    6,973
    No, I didn't know about it..
    Usually when I saw the word expression, I went screaming away from the computer.
    But I guess it really pays to learn this stuff, so I'm back.
    Sager
    12G 1600mhz mem
