Results 1 to 12 of 12
Thread: Render and keep working...
    I've just posted the Mac version of a new plug-in/lscript called Launch Mode3. You can read about it here:
    http://vbulletin.newtek.com/showthre...&threadid=1856
    "One of the things we really have to impress upon people is that it is never good to be fed on by a blood-sucking insect"
    Dr. Anthony Marfin, CDC
    This script has now been updated with some minor speed improvements, and the ability to work with the windows version of Lightwave.
    there *me points*
    72
    Cheers mlinde
    [color=orange][b]crémegg[/b][/color]
    excellent!
    thank you!
    Lightbulb Update to current scripts
    Hello all.
    I've just updated a few of the LScripts I have written, and moved them to a different site as I am transitioning between hosting solutions. First of all here's the link:
    http://www.geocities.com/mlinde/
    Now, the skinny:
    1) There's a new script that does all sorts of fun things to help you load a new scene. Julian Johnson was mentioning the steps he goes through to load, and I thought I'd help him out, but everyone can try it. It's called "Setup & Load Scene"
    2) I'm in the process of updating my Mode3 script (to set up external rendering) with a few new features, but I wanted to share the news early. Here are some of the upcoming features:
    - Automaticaly Generate Mode 2 or Mode 3 command line files
    - Initialize with customized configuration to allow changing the content directory while working in Layout and Rendering with ScreamerNet.
    - Choose multithreading options for each project.
    Oh, and all of these are cross platform, but the LaunchMode3 has two different versions right now.
    very cool mlinde!
    will these work in 7.5c?
    thank you
    Confirmed -
    btw I have a "poor man's" reder-and-keep-working method, copy the LW folder and re-name the app. You can then run 2 copies, but only if the hub's off.
    Confirmed -
    Originally posted by toby
    very cool mlinde!
    thank you
    Sadly, no. The scripts utilize the File(); command which no longer fuctions correctly with 7.5c/ LScript 2.6.1
    maybe with the next update they will work again though!
    i don't remember
    oopmaoonars
    115
    yep, very nice indeed.
    thanks alot.
    all snowy in the pond - Tim Smith
    Midnight coding Madness!
    So I've finished the upgrades to the plugin/script I created for setting up LWSN nodes. The newest version can be had at:
    Here's the fun things you want to know:
    Launch Mode3 is now called Screamernet Setup.
    Features:
    - generates the command files for both Mode -2 and Mode -3 LWSN rendering. If you don't know what that means, it's in the manual under "distributed rendering."
    - generates a custom configuration directory (inside the current content directory) that is referenced by LWSN. This allows you to render one project and still utilize all the features of Lightwave (including changing the content directory for another project)
    - works for both Macintosh and Windows Lightwave ***NOTE: Macintosh 7.5c has a bug with LScript 2.6.1 that prevents this script from functioning. You must use LScript 2.5 (which shipped with 7.5) or earlier An upcoming release of Lightwave or LScript should fix this problem.
    - takes the trouble out of typing up cmdline files or .bat files
    - still 100% FREE!!!
    He's outta control! Somebody stop him before he gives it all away!
    btw, any serious drawbacks associated with back-dating the lscript?
    Confirmed -
    I don't know, actually. I know that none of the scripts shipping with 7.5c require 2.6.1. I don't know if the program will freak with an older version. You can always save the current one and try it!
