Thread: Hypervoxel dented texture missing after 7.5b update
    Captain Rugburn save me!
    Riverview, Florida
    148
    I noticed that the dented texture is missing from the hypertexture selections within the hypervoxel 3 interface. This has happened after I updated to 7.5b. Is anyone else having the same trouble? Any suggestions?
    Thanks,
    Troy McClellan
    The Dented texture is still there with my LW 7.5b.
    Hmm weird...
    CU
    Elmar
    Riverview, Florida
    148
    I tried scanning the plugin directories and I still do not have the dented texture in the volume or sprite modes. I'm not sure if I closed the hub before installing. Would having the hub open during install cause this?
    Troy
    I have the same problem, my dented textures are missing!
    I fix that only when a copy the old RAPTS.p file, the new one come with 7.5b update are broken, use the old one come with 7.5 only.
    Gaetan T.
    Lead FX
    [email protected]
    www.hybride.com
    Resume / CV
    http://www.linkedin.com/in/fxgaetan
    Riverview, Florida
    148
    I just did a very similar thing. I was not sure what file the textures were contained in so I installed 7.5 on another machine, copied the plugins and l-scrips and then pasted them into my 7.5b install. Now they are back. I guess in my ignorance I did things the hard way. I will keep that file in my notes as to avoid these problems in the future. Thanks for your help.
    Troy
