Thread: Script error in 7.5b
    Unhappy Script error in 7.5b
    Getting a "Can't load ...' error.
    I use this script called by a Custom Startup Command. This is the script (PolyModeSelect.ls):
    main
    selmode(USER);
    selpolygon(CLEAR);
    Sets mode to Polygons on start up. Worked fine in LW 7.5.
    Meddle not in the affairs of dragons
    For thou art crunchy
    And go well with ketchup and cornbread.
    Lightwave Pimp Skonk's Avatar
    Yorkshire UK
    1,450
    They change several things in the new version of lscript so some old scripts wont work without modification, im not a scripter so i can help u on your spicific problem, the lscript forum would be of a more help i think
    James..
    uh wha?
    I've had nothing but grief with this version and on two machines. The latest is that 7.5 crashed when trying to load an object made in 7.5b. I vented some about that in another thread because 7.5b couldn't find my config files (right where they're supposed to be) either, etc.
    But then ... maybe I'm just an idiot - for installing 7.5b that is.
    then stop being one, learn from your mistakes and revert back to 7.5. that's what i did because i found lscript 2.6 unacceptable. i have lived well without headaches before 7.5b. i'm going to wait for lscript 2.6.1 before i considering patching.
    remember, nobody's forcing a patch on you.
