Thread: 3P1 please update file export to used tagging data for filename
    Sep 2014
    London
    110
    Have been instructed to enter a feature request for a 3P1 in the Tricaster area.
    On the old 3Play systems when you use the shortcut keys on the panel to use hotkeys to name a file. This data was used as the filename when exporting
    On the 3P1 this is not the case and you have to manually rename each clip.
    This slows down the speed of being able to push clips out to our FTP server which in turn delays delivery
    Please can this work as it does on all the other 3play systems.
    Thank you.
    Sep 2014
    London
    110
    hi any update on this?
    Sep 2014
    London
    110
    Just discovered there's a 3Play requests section. I posted here as this was the link given by support. I'll make a new on in the right section. Cheers all.
