is there a way to get FBX file bones into Modeler, or a way to convert them to do so? I don't want to start from scratch and use Genoma or LW bones.
Into Modeler?
Into Modeler you can't even import LW bones.. (at least not natively)
Modeler has skelegons, not bones.
They don't contain envelopes and a lot of other interesting features of bones..
TrueArt Christmas Promotion with free gift Sasquatch Resurrector!
Sasquatch in LW 2020.0.2:
https://youtu.be/9_kI_IcNA9k
What are you importing from?
Generally, you'd open the FBX in Layout. I bring a lot of assets in from Daz via their FBX export. When opened in Layout, although they're all aligned to the Z-axis, but because of the wt. mapping they work just fine in FK. The first two bones in the hierarchy need to be removed BTW.
So you have the mesh, which can get sent or opened in Modeler, but the bones at this point would be edited in Layout. I used to be terrified of that, but overcame it once finding a decent tut or two, and it's not all that difficult after all.
The Big Apexx System:
64GB
guess you could...
tho' certainly not sure if you should.
erikals,
What affect does this have on any existing wt. mapping assignments for the bones?
64GB
none as far as i know.
those would have to be made over again.
almost all settings are lost i think.
could be useful in a worst case scenario, other than that...![]()
hm, shame looks like d-storm removed almost all plugin links.
well, thank goodness for...![]()
https://web.archive.org/web/20170512...oad_Bones.html
And if you're using that, you likely also want...
https://web.archive.org/web/20170512...gonEditor.html
