Thread: iPhone NDI Camera Capture Camera Switching Between Lenses?
    May 2020
    Germany
    2
    Hello NewTek Team (and everybody else reading),
    I just discovered your NDI app on iPhone and it's awesome to be able to use this in OBS Studio as a source with audio and everything. I also love the fact that you are actively developing it and making improvements.
    I am using the latest iPhone 11 Pro Max with 3 back cameras and one front camera and would like to request the possibility to switch between the back cameras.
    1) Switch between back cameras (most iPhones have 2, the latest 11 Pro have 3)
    2) Make "speed meter" clearer to indicate which resolution is being broadcasted (I feel the simple speed metering is a bit unclear and if I would not have found out about what it means on a support article here, I would have not known.
    3) a way to "center" the exposure dial (in most applications I know, simply double tapping something like the exposure dial would recenter it there, that'd make the use a bit easier).
    Other than that, thank you again for providing this and I look forward to these (and other) updates.
    To be clear, the most important question is about #1 here and the option to be able to switch between the back cameras of the iPhone which has 3 on the iPhone 11 and 12 Pro versions.
    Thanks again,
    Chris
    Nov 2020
    Russia
    8
    I've heard that the NDI HX camera app allows you to use your iOS device's camera as an NDI source. I would like to know how to broadcast live from iOS devices.
    19,996
    Unless you have broadcast devices or software that natively support NDI input, the usual approach is to install NDI Tools (free) and use the included Webcam Input app (formerly called "Virtual Input") to present a selected NDI source to your other applications as if it were a webcam.
    Aug 2015
    london
    296
    Quote Originally Posted by ChrisSpiegl View Post
    Thanks again,
    Chris
    The Sienna NDICam app for iOS has an 'Auto Lens' preference which allows the iPhone to switch between cameras based on Zoom level. This was added specifically to support multiple main cameras. I can't say it has been tested with 3 cameras, but this setting does appear to have been tested working with earlier 2 camera devices, and since its an OS level decision (the app isn't deciding which camera), I suspect it will scale to work with all 3 main cameras on your phone.
    Version 5.02: Added Multi-Lens Support
    https://apps.apple.com/us/app/ndicam/id1074065391?ls=1
