Thread: All Media Clips in Bin get same transition
    Registered User BenMakesTV's Avatar
    Oct 2014
    United States
    35
    I'd like to be able to delegate a transition to an entire bin, and with a checkmark or something, even without manually adding every transition, everything in that player gets a transition. The use case - I have a bunch of lower thirds, EVERY SINGLE TIME i want them to fade between each other, and it's a pain to have to add them or do a select all ad thing or move around the floating transitions.
    Jun 2006
    Chicago, IL
    698
    You can use Ctrl-A to select all elements in the bin and apply a transition to all simultaneously.
    Not quite as clean as a default transition but still not as bad as adding each manually.
    Fritz Golman
    Oct 2014
    United States
    35
    Yeah. Not ideal though for my use case - but definitely the way I do it for now.
    19,985
    My recollection is that Alt + f does something like using the last last selected effect. I don't think it's limited to just fade, but still they'd all be the same. This could be pretty easily turned into a macro, I think.
