There should be a way to set a default duration for still imports. 5 seconds is dumb! I want everything to come in at 60 seconds. Let us choose that!
I added a feature request for this.
In the mean time, you can select multiple clips (or press Control-A to select all) then adjust the duration of a selected clip and all will be adjusted. It gets you the end result you are looking for, even if it is done by a different set of steps.
Thanks! That's what I do now - problem is when I have other videos in there it doesn't show up as an option, and the bigger issue - I just forget to do it!
