Results 1 to 14 of 14
Thread: LW Modeler 2020.0.2 Backdrop image??
    Registered User sami's Avatar
    TopLeft Viewport
    1,100
    Question LW Modeler 2020.0.2 Backdrop image??
    Just tried to load a background image into modeler for reference in 2020.0.2 for the first time and it doesn't show up on screen in the viewport?
    Unless it's user error I don't know what is wrong or if it's a bug. Image Editor shows the image ok and i tried PNGs and JPGs but when I assign it to a viewport in Display options nothing happens. Standard NVidia card latest drivers... not sure... Any one know what I'm doing wrong?
    thanks!
    there is no sanctuary....
    Mar 2004
    Rochester Hills, MI USA
    545
    Something I hadn't tried since installing 2020.02. Works fine here, played with it a bit to see if I could get it to break, but it's working.
    Bill Carey
    3900X 3.79
    Win10 Pro 64bit
    32gig Ram
    AMD 5700XT 8gb 20.4.2
    LW 2020.02 x64
    Space Navigator
    TopLeft Viewport
    1,100
    thanks for checking.... wonder what my problem is....
    Frequenter
    Sep 2003
    Munich
    529
    Any chance there is an alpha with the image that somehow clips everything? What happens if you disable Alpha Channel in the image properties (Source Tab)?
    17,382
    You are in perspective mode, use camera mode..backdrop images arenīt visible in perspective mode.
    If you use textured environment, that will be visible in perspective mode though.
    TopLeft Viewport
    1,100
    thanks - but I'm nor sure what you mean - In this screenshot it shows I'm trying to change the BotR viewport which is "Back" and orthagonal. The TopL one here is in Perspective. So it's not working for me.
    - - - Updated - - -
    Quote Originally Posted by fishhead View Post
    Thanks for checking - nope - I've tried several images including JPGs without alphas and nothing shows up.
    8,347
    Check different images, JPG, PNG, TIFF, with alpha, without alpha,
    Check different viewports, zoom-in, zoom-out,
    Check different OpenGL settings,
    Clean up configs, reload all native plugins.
    etc. etc.
    Mar 2004
    545
    Quote Originally Posted by sami View Post
    Out of curiosity, what's your grid size?
    Bill Carey
    3900X 3.79
    Win10 Pro 64bit
    32gig Ram
    LW 2020.02 x64
    Space Navigator
    17,382
    - - - Updated - - -
    As you clearly see, and I was talking about camera, it seems I didnīt have the coffe working yet when I wrote that, too hasty response since I thought it was a Layout issue.
    Sorry about that I must have had a temporary brain melt down when answering you, and I donīt think I can help you solve it since I donīt have 2020 installed either.
    Anyway..good luck.
    Yes 180mm seems ridiculously small, when you open modeler it defaulted to a 500mm grid, meaning that in order to place a reasonably sized image in a viewport it will need to be around 10 meters which is around 50 times greater in size than 180mm
Name:	Screenshot 2020-10-31 at 20.01.09.png
    Pleased to meet you. Oedo 808's Avatar
    Apr 2008
    London
    1,575
    Make sure you haven't hit View > Viewports > Toggle Backdrop at some point by mistake. If it clicking it doesn't solve your problem make sure to hit it a second time because if you do find the solution, it'll now be hidden.
    Sentenced to 310 years for crimes against modelling and rendering.
    Mar 2004
    545
    Quote Originally Posted by gerry_g View Post
    Yeah, that's where I was going. 180mm may be the correct size for what they are modeling, but if the grid size is 2m or more it won't show up at all unless you zoom in a bit. 500mm at least shows up. Oedo 808 probably has it though.
    Bill Carey
    3900X 3.79
    Win10 Pro 64bit
    32gig Ram
    LW 2020.02 x64
    Space Navigator
    TopLeft Viewport
    1,100
    etc. etc.
    Thanks I checked everything except cleaning up configs and reloading all native plugins.... maybe that's next
    - - - Updated - - -
    Quote Originally Posted by Bill Carey View Post
    It was at 200mm but I tried other ones and didn't see any results with the backdrop showing up
    - - - Updated - - -
    Anyway..good luck.
    no worries - thanks for replying!
    TopLeft Viewport
    1,100
    Quote Originally Posted by Oedo 808 View Post
    it works now!
    Ah yes!! thank you... it was a combination of grid size and Toggle Backdrop - Since I never used Toggle Backdrop in this install - I wonder if it was hidden by default? Despite having used LW for many years, I didn't even really know about the toggle backdrop function in the View menu.
    This was all probably just my user error... I was zooming in and out before when I didn't see the backdrop image - but I guess it was hidden - plus trying to see a 9cm object with a 200mm grid was not right. Thanks for that! much appreciated!
