Results 1 to 9 of 9
Thread: Need help with Rounder
    Mar 2010
    Virginia
    54
    Please help with rounder tool error. When I apply the rounder tool to the selected points (attachment). I get the error saying that 'the selected point is not inside the selected polygons'. To get the selected points. I used extender plus, size and extrude.
    I have LW 2018.
    Many thanks in advance
    Hung
Name:	Rounder Error.jpg
    Feb 2006
    england
    1,430
    most likely cause, deselect all points then use "merge points" its likely points are not welded,
    also it could be flipped, open edged polys ,2 point polys, and double polys can cause it, likely something happened when you bevelled, (e.g. accidently hitting the left mouse can cause 2 point polys to be created in a ring)
    Mar 2010
    Virginia
    54
    Thank you very much rustythe1, A 'merge points' indeed fixes the error. It's time to press on
    Thanks again
    8,347
    Forget about Rounder.
    Professionalists work in Sub-Patches.
    Get Swift Edge Loop
    This took me just a few seconds (it took more time making this reply):
    I recreated your original object.
    I clicked RMB on edges to split them, then repeated, then repeated again, until there is enough edge loops.
    I clicked RMB+CTRL on edge loops which we don't need. They were just temporary made.
    Sub-patched version with smooth rounding...
    It took just a few seconds to make, and it is low poly object (in comparison to what is needed with Rounder and normal polygons).
ID:	148937   Click image for larger version.
ID:	148938   Click image for larger version.
ID:	148939   Click image for larger version.
ID:	148935   Click image for larger version.
    8,347
    A couple RMB+CTRL and couple RMB more..
    Removed sharp edge loops.
    and it is even more visibly smoother:
ID:	148941   Click image for larger version.
    May 2003
    Ohio
    1,289
    Professionalists work in Sub-Patches...
    Indeed. You can achieve better results with far fewer polygons.
    https://docs.lightwave3d.com/lw2020/...patch-modeling
    LW4, 7.5D, 2015, 2018, 2019, 2020 running portably on a USB drive.
    Active LW Development in 2020: DB&W | Deep FX | DPont | LWCAD | TrueArt | ...
    ex-LightWave documentation BeeVee's Avatar
    Pessac
    5,264
    That is a brilliant tutorial from Richard Culver. It's old but it's still as pertinent as ever.
    B
    PS. Forgot to mention we now have useful tools for working with subpatched geometry like https://docs.lightwave3d.com/lw2020/...ges/edit-edges. Watch that first animgif to see how a box can be rounded nicely...
    PPS In 2020, you also have the Local action center to help when working with more complex objects...
    Ben Vost
    LightWave 3D Docs wiki
    AMD Threadripper 1950X, Windows 10 Pro 64-bit, 32GB RAM, nVidia GeForce GTX 1050Ti (4GB and 768 CUDA cores) and GTX 1080 (8GB and 2560 CUDA cores) driver version 456.71, 2x4K 23.5" monitors
    Mar 2010
    Virginia
    54
    Thank you all for a wealth of info.
    Pessac
    5,264
    It's amazing, almost like someone spent hours collating info and putting it all in one place
    B
    Ben Vost
