Thread: Discovery Server support
    Mar 2018
    Sweden
    9
    Spark Plus 4K, Spark Plus IO SDI, Spark Plus IO HDMI and the Mini 4K Input Modules all get NDI Discovery Server support and improvements.
    Does NewTek NDI-PTZ1 also get Discovery Server support?
    NDI-HX v1 (which is what the NDI-PTZ1 Camera uses) doesn't support Discovery Server.
    In general this will not be an issue to use the camera with other Discovery Server devices. You can setup remote sources and devices that are connected to Discovery Server will continue to see NDI-HX v1 sources.
    Mar 2018
    Sweden
    9
    I work at a hospital where we have customers who want to borrow PTZ cameras to connect to the network during lectures / simulations / operations. Where we then want the opportunity to connect to the cameras and record.
    The problem is that we have many different subnets and do not have the opportunity to know the IP number of the connected cameras. As I understand it, with NDI4 and Discovery Server it is possible to "find" these cameras if they support Discovery Server function.
    I have tested the NDICam app on my Iphone which supports Discovery Server function, and it works well in our network.
    https://www.provideocoalition.com/wp...te-8815214.jpg
    I have seen that Kiloview has added this feature to its convectors.
    https://www.youtube.com/watch?v=NjAcBTrC_J0
