Thread: Modeler to Layout Textures 2020
    Jan 2011
    Earth
    57
    Hey! - Textures Look great and everything is showing up perfectly in Modeler but when I open my model in Layout the textures are either not showing up at all or are completely white. Any idea what's going on? Thanks
    ex-LightWave documentation BeeVee's Avatar
    Pessac
    5,264
    Are you in a display mode like Shaded? Change the viewport display to Textured Shaded Solid for a view of your surfacing but bear in mind that Layout's OpenGL can only show the first layer of a nodal network. Anything you can see in Modeler can be seen in Layout.
    B
    Ben Vost
    LightWave 3D Docs wiki
    AMD Threadripper 1950X, Windows 10 Pro 64-bit, 32GB RAM, nVidia GeForce GTX 1050Ti (4GB and 768 CUDA cores) and GTX 1080 (8GB and 2560 CUDA cores) driver version 456.71, 2x4K 23.5" monitors
    Near Beaverton, OR
    2,035
    Check your surfaces, F5. I suspect the Diffuse might be too low but in particular the Spec & Gloss are way too high. On imported items, I generally just set Diffuse to 100 & Spec to 0 which should set Gloss to 0 as well until I can get some maps in place.
    The Big Apexx System:
    64GB
    Super Member vncnt's Avatar
    Sep 2003
    Amsterdam
    1,779
    If that also fails, check your OpenGL settings in Preferences and make sure OpenGL Textures is active.
    easy way to see if excess brightness is a specular problem is to disable it for al the lights, find that if I am using Standard material for a textures I put a Fresnel shader in the specular channe,l PBSDF is what the renderer is set up for these days and tends to work better but even then it needs a little help
    Jan 2011
    Earth
    57
    Thank You !!
