Thread: Transparency with Zero refraction
    Jul 2018
    Philadelphia
    40
Name:	Screen Shot 2020-10-15 at 3.08.04 PM.png
    I created this model in LW2018 and have the material on standard. It's supposed to be a block of chocolate with a stick sticking out of it inside a clear plastic box, a situation in which there would be little to no distortion of the object. I set the refraction to zero, but still have tons of distiortion. How do I fix this?
    San Jose, CA
    7,204
    Quote Originally Posted by Commander_Chaos View Post
    Are you using the last revision of LW2018 (2018.0.7)? If not, try with that? Maybe provide the object/scene, or minimal example that causes the same artifact, so we can check geo, etc?
    John W.
    Cumbria UK
    528
    Am not at my laptop so can't confirm, but isn't a refraction index of 1 'zero refraction'?
    LightWave Fan Boi
    Dec 2009
    London, England, UK
    1,198
    Blog Entries
    18
    Quote Originally Posted by kyuzo View Post
    Yup. Setting the refractive index to 1.0 will make it have zero refraction. Provided of course that your model is airtight an constructed properly.
    Tested and confirmed.
