Results 1 to 15 of 17
Thread: LW 2020 to Ue4 help
    Aug 2006
    UK
    318
    LW 2020 to Ue4 help
    I'm completely new to Unreal Engine so don't know if anyone can help me with this?
    I used the LW Bridge to unreal engine to send my model over but it seems as if UE doesn't use uv maps as although the maps are sent over the object remains grey. Is there a special way of doing this? Something I need to change in the LW maps before bridging to UE?
    ack ack Markc's Avatar
    Feb 2006
    England
    1,650
    Can’t help you sorry, but there is a Ryan Roye vid on Liberty 3D for this.
    It’s pretty expensive (about $65), but as all Ryan’s videos, well worth it.
    Have you looked on YouTube.
    Mac Pro (2010) OSX 10.14 RX580 Pulse LW2020
    (plugins: LWCad 2020, TFD 1443, Syflex 2018, StarPro 2020, ExrTrader 2020, Ubercam 2.0, Daz Mocap, DP Light 2020, Quadpanels 1.5)
    8,367
    Do you have UV maps attached to some surfaces in LightWave?
    Which LW version are you using?
    In the case of OBJ export, UVs must be attached to surface. People frequently forget about it.
    Aug 2006
    UK
    318
    I'm vers. 2020.02 using principled BSDF node textures uv mapped to surface.
    8,367
    Quote Originally Posted by genesis1 View Post
    Then try one of earlier versions e.g. LW 2015, and configure UV mapping in regular Texture Editor, to see if it changed anything..
    Aug 2006
    UK
    318
    I already tried with regular standard textures and nothing goes through. With node textures, they go through but just not mapped correctly and there seems to be no simple uv map selecter in Ue4.2 to correct it. I've spent ages just trying to get a uv map right. It maybe to do with the item having a zbrush uv map. It's a real pain. I guess I might have known it wouldn't be as simple as activating LW Bridge to UE and sending them across with correct uv's.
    8,367
    LW 2018+ does not have "standard regular textures" (what you see in Surface Editor in LW 2018-2020 is just "fake" to look like as in old LW, for older customers to be happy).. You must try it on LW 2015 or LW 11..
    What is important is whether UE4 exporter has been properly updated to support new SDK with new surfacing system.
    8,367
    Try from something ultra simple. Make quad polygon.
    Aug 2006
    UK
    318
    Found out the problem or at least I think I have. After sending the object via LW to UE Bridge I altered the scale of the object in UE before applying the textures so this messed up the application of the uv textures. I tried it by adding the textures first before resizing in UE and it now works. I will double check tomorrow but that seems to be the cause.
    Registered User Skywatcher_NT's Avatar
    Nov 2006
    Belgium
    179
    Why not use the Unreal Shader?
    Aug 2006
    UK
    318
    Quote Originally Posted by Skywatcher_NT View Post
    I've only just begun with Ue4 so need to learn a lot, but it's a character head I've imported so need the texture maps. Wanted to see how it would look in UE.
    ex-LightWave documentation BeeVee's Avatar
    Pessac
    5,266
    The Unreal Bridge is only available in LightWave 2019 onwards. It is not available in earlier versions of LightWave, so saying to try in 11 or 2015 makes no sense.
    B
    Ben Vost
    LightWave 3D Docs wiki
    AMD Threadripper 1950X, Windows 10 Pro 64-bit, 32GB RAM, nVidia GeForce GTX 1050Ti (4GB and 768 CUDA cores) and GTX 1080 (8GB and 2560 CUDA cores) driver version 456.71, 2x4K 23.5" monitors
    B
    BeeVee, are you still working on the docs and should we still send you suggestions and/or corrections?
    Tim Parsons
    Pessac
    5,266
    Hey, Tim. Not since August, although I did make sure that there's a PDF export from the wiki available in your NT user account, in case VizTek decide to stop the wiki.
    B
    Ben Vost
    Frequenter
    Sep 2003
    Munich
    529
    Hi BeeVee, thanks for your continuing support! You are and have been a great asset to the community. To sad they let you go... :-\
    VizTek? Is that a hint of some sort? ;-)
