Results 1 to 15 of 15
Thread: Surface/Normal blending in LW
    Registered User WaveRider's Avatar
    Dec 2014
    origin
    23
    Question Surface/Normal blending in LW
    How can I achieve something like this in LW with two separate surfaces?
    https://www.youtube.com/watch?v=SjtItfeyHII
    8,263
    With two separate surfaces, you can't do it in LW.
    With single surface you can use Gradient/Weight Map, and Material Mixer.
    But you can do it in TrueArt's Global Materials.
    http://globalmaterials.trueart.eu
    There is separate version for LW v11.x-2015.x, and for LW 2018-2020.
    Basically entire surfacing you should move to Global Materials global Node Editor, and in GM you can have access to both materials used on surface A and B in the single Node Editor, and eventually you can mix them together using Material Mixer, as you wish.
    Dec 2014
    origin
    23
    Is that due to internal limitations of how LW handles surfaces?
    Thank you, I'll consider purchasing it.
    8,263
    Quote Originally Posted by WaveRider View Post
    It is quite natural limitation.. the same you have in e.g. OpenGL, DirectX...
    Polygon can have just one material assigned at one particular moment.
    To support multiple materials on single polygon, there is needed redraw of the same polygon multiple times with alpha which adds to 1.0. e.g. 0.8 from 1st material and 0.2 from 2nd material.
    Which would make OpenGL (or rendering) many times slower than it is now.
    Some people make such changes in post-production.
    8,263
    Suppose so we have two surfaces, which have sharp boundary like on screen-shot #1.
    Both Principled BSDF materials in LW 2020.0.2.
    One is greenish (pretending grass).
    Other one is brown (pretending rocks).
    We want to smoothly blend one material to other.
    I created weight map, and plugged it to Gradient to be able to adjust it without having to modify weight map. Then to Material Mixer.
    Instead of Gradient, you can add Multi Material Switch node, and connect multiple different materials to it, and switch them easily from one version to other version during show to client different surfacing.
ID:	148758   Click image for larger version.
ID:	148759   Click image for larger version.
    Feb 2005
    Barcelona
    334
    Seems to me like a surface being affected by a mask based on +Y axis and blended with a camera projection
    Mar 2018
    Perth, Australia
    158
    First of all, WOW!!!! thats an amazing feature!
    Second, looking at the video closely you can see that the ground material is actually sticking onto the rock (it rotates with the rock, meaning it is part of the rock and not the ground). I think this means means that you would have to have the ground material inside the rock object next to the rock material and use some kind of fancy ray detection thing 'I obviously suck at using nodes properly) and then use a material mixer to mix both ground and rock texture with the data from that ray detection thingo....
    Makes sense in my mind, I just can't make it work with nodes though...
    @sensei
    your example is 1 object. In the video it's clearly 2+ objects. So the question is can 2 separate objects detect intersecting geometry and use that data?
    Mar 2018
    Perth, Australia
    158
    Correction.... in the end of the video you can clearly see the ground texture stays put while the rocks rotate.... Oh well, maybe just make the ground texture World coordinates and the rock texture local or something.... what do I know, still would be a very powerful feature if LW could have that.
    8,263
    Quote Originally Posted by peebeearr View Post
    @sensei
    It does not matter how many objects you have. It is one global Node Editor for all objects all surfaces (or the one which you want).
    GM does not detect any geometry intersections.. It is global Node Editor. So definition of grass and rock materials would be in one place (instead of two places). So blending them together is trivial.
    May 2006
    France
    4,208
    I made some experimentation close to this effect,
    the ball has the same UV map name than the box,
    native image node set to Object UV, offsetting the U & V for the Ball,
    alas it is slow to render.
    Denis.
    8,263
    If you could send occlusion ray which is not detecting self occlusion result of it could be used as parameter to LW 2018+ clip. It would work in some camera orientations when secondary material is behind primary material.
    May 2006
    France
    4,208
    Found another way for such similar edge blending,
    with one evaluation per Color and one per Normal, so faster to render,
    but not a "one node" solution.
    No Blending:
    Blending:
    using the Replace Spot node from DP Filter,
    I updated it with a new "Ray Direction" input,
    when pluging a normalized direction vector,
    the node fires a ray for catching the underlying object and replaces current local, world and uv coordinates
    by those found on the intersected object.
    So taking the normal output from the native Edge Shader node,
    get the Normal for smoothing,
    also inverse it with the Vector Scale node to plug a Ray Direction
    in the Replace Spot node placed after the same Image mapping
    than underlying box object.
    Input what you want in the Mixer node for texturing the rest of the ball object.
    the edge output modified by the gradient may be used for mixing
    some other part of the current object material with the underlying object material.
    Here a Grass procedural texture with Object UV mapping,
    Denis.
    Dec 2014
    origin
    23
    @dpont
    Excellent, thank you for sacrificing your time. It's a great start, I will try it this way.
    May 2006
    France
    4,208
    I attached my animated test scene above.
    UV-crossing.ZIP
    Didn't mention that beside this ObectUV mapping,
    other world or local coordinates mapping is possible,
    also you can get Bump output, will be blended
    with the normal.
    Denis.
    Dec 2014
    origin
    23
    Great, thanks again dpont.
