Results 1 to 12 of 12
Thread: Discovery mode?
    Jan 2005
    Colorado Springs
    1,868
    Discovery mode?
    I have been using LW2015 and LW2019 without a problem (haven't upgraded to 2020 and won't), although I haven't tried it in several weeks.
    Now, with no changes at all to my LW configuration, LW 2015, LW2018 and LW2019 all come up in discovery mode.
    Downloading the LICENSE.LWK file from my login on the Lightwave3d.com website and installing it doesn't help in any of the above versions.
    Ideas?
    Thanks,
    mTp
    Video Junkie Vong's Avatar
    Eagle Mountain, Utah
    325
    I'd suggest trying this is you are on Windows.... https://www.liberty3d.com/2017/12/8995/
    Curtis Rhoads
    Desktop: Win10 x64 | Ryzen 7 3.7GHz | 32GB RAM | GeForce GTX970/GeForce GTX1660
    Laptop: Win10 x64 | i7 2.3GHz | 8GB RAM | GeForce GT650M
    Near Beaverton, OR
    2,012
    If that doesn't do it mTp, contact Deuce with Tech Support. I was looking for the boilerplate procedure he'd sent me but of course can't find it now. Basically it was moving or deleting one folder that LW would rebuild upon start. From there it was just dragging the license onto splash screen as usual.
    The Big Apexx System:
    64GB
    8,263
    LW saves configs in
    C:\Users\[user name]\.NewTek\LightWave\[version name]
    e.g.
    C:\Users\Sensei\.NewTek\LightWave\2020.0.2
    Deletion/rename of config folder is typical practice of fixing issues..
    It is recreated when LW starts.
    Then you copy license to:
    C:\Users\[user name]\.NewTek\LightWave\2020.0.2\licenses
    Jan 2005
    Colorado Springs
    1,868
    No luck.
    Went through the video process.
    Removed config folder, restarted, drag-n-drop license to splash screen
    Copied LWK file directly to C:\users\moe\.Newtek\Lightwave_2015.3\licenses\LIC ENSE.LWK
    Disabled Windows Firewall completely
    Disabled anti-virus software completely
    No time to mess with it.
    mTp
    17,241
    Uninstall every lightwave version, reboot the computer, install the versions you need.
    Save your installed plugin folders to manually replace after fresh install.
    Only way to be sure
    May 2003
    Ohio
    1,263
    There are a lot of drastic actions recommended for something that may not need more than a minute of effort. Does LW present an error message at start? If so, what is it?
    LW4, 7.5D, 2015, 2018, 2019, 2020 running portably on a USB drive on an Amiga 2500 running Wine.
    ex-LightWave documentation BeeVee's Avatar
    Pessac
    5,253
    Is the gap in license.lwk on purpose? Just a typo, or is that what the file is called? If it is named like that, remove the space...
    B
    Ben Vost
    LightWave 3D Documentation
    AMD Threadripper 1950X, Windows 10 Pro 64-bit, 32GB RAM, nVidia GeForce GTX 1050Ti (4GB and 768 CUDA cores) and GTX 1080 (8GB and 2560 CUDA cores) driver version 456.38, 2x4K 23.5" monitors
    Near Beaverton, OR
    2,012
    Oh wow.
    ... and if that is the case, smack BeeVee's Avatar firmly on yo forehead!
    64GB
    Jan 2005
    Colorado Springs
    1,868
    B
    No, this is a forum "bug" or behavior. If you use particular strings of characters, the forum utility puts a space in it.
    Here's the screen capture:
    and here's me typing in the path without a space in "license" (honest!):
    C:\Users\Moe\.Newtek\Lightwave\2015.3\licenses\LIC ENSE.LWK
    I think it has to do with "tags" that the forum uses to translate into other things, like (that's me typing a colon followed by a close paren) being automagically turned into a smily emoticon.
    Dunno.
    mTp
    San Jose, CA
    7,113
    Yep, vBulletin can be an... odd... creature at times.
    John W.
    Jan 2005
    Colorado Springs
    1,868
    FYI, this has been resolved. It was a combination of two things: some outdated application behavior rules in my antivirus software (deleted and re-created), and executing the Lightwave configure utility with Administrator privs, using the unset / set commands as described in the video.
    The short-n-sweet description of the configure utility process is:
    1) Invoke CMD prompt with Administrator Privileges by right-clicking it
    2) Use DOS cd command to navigate to the LW product /bin folder
    3) > configure unset
    4) > configure set
    Note that turning OFF the Windows firewall entirely in Control Panel doesn't seem to override this LW configure setup requirement.
    mTp
