Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: Random SSS Node
  1. #16
    England
    6,045
    Have you tried baking the irradiance cache?
    Irradiance caching takes a different sample each frame, so it will be different each time. Baking the irradiance cache should stop it, unless this is a bug with the SSS?
    - - - Updated - - -
    The difference in your two frames is the noise though, where LW's renderer (as most renderers do) takes a Russian roulette approach to firing samples... you have to increase the samples in order to remove the flickering from each frame.
    Maybe I'm misunderstanding the issue, but brute force, reflections, shadows all have this Russian roulette sampling... it is always different per frame.
    Desk Work:
    Desk Home:
  2. #17
    Aug 2017
    Slo
    151
    - - - Updated - - -
    I will comment on Irradiance caching later, but yes I have baked frame and there is an issue at least for me. It seems that "Clear cache" button does not work as expected.
    If LW have a Russian roulette approach, why there is NO difference if you render twice a single frame?
    My last renders that I showed are all WITHOUT GI as well as Johns.
  3. #18
    England
    6,045
    Quote Originally Posted by next_n00b View Post
    Yeah, there does seem to be a problem with clearing the cache, but not entirely sure what it is.
    I tend to go an manually delete them. If you overwrite them it will cause major issues if you move things, or change the lighting.
    Russian roulette sampling generates a random seed per frame, so if you render the same frame twice, it looks exactly the same. This is what most render engines do.
    Desk Work:
    Desk Home:
  4. #19
    Aug 2017
    Slo
    151
    Exactly that! Even if you change samples, it seems that the baking procedure expand the cache file in an inappropriate way.
    If this is the case, it is new to me, and I wonder WHY? Why the engine would work that way?
  5. #20
    England
    6,045
    It's this way because it removes the weird effect of static noise.
    I've tested a static noise renderer before (this could be done in LW's renderer as an option maybe) and when you move through an environment, or objects move around it looks like they are moving through a cloud of static dots. It generally looks really strange.
    The random noise method is used in most renderers these days as it enables them (like in Arnold) to ditch 50% of the samples through glass or do clever things with the samples, that don't cause horrendous artefacting.
    Desk Work:
    Desk Home:
  6. #21
    Aug 2017
    Slo
    151
    Yes, I think I answered to myself in the meantime, that must have something to do with camera movements and blending frames together to deceive the viewer.
    But what about Sensei point of view, he said, if frames differ, it is a bug. It seem to me as a knowledge man.
  7. #22
    England
    6,045
    Yeah, not sure what Sensei means... he's a very clever guy, so I value his views.
    Desk Work:
    Desk Home:
  8. #23
    San Jose, CA
    7,113
    Now I am lost. I have tried the same thing in 2018 version and the behavior is the same. Renders are different from frame to frame with Sigma node or Principled BSDF with Subsurface enabled. What part I don't understand I ask myself?
    The various "translucency" shaders have been a mess* since LW2018. That an "SSS rewrite" occurred with LW2020, yet the shader(s) are still fundamentally broken in similar manners, highlights the problem.
    *: Unstable shader results, broken with basic light types, etc. Bugs filed in LW2019 by myself and others.
    John W.
  9. #24
    the other part of of SSS is Caustics, did any of you up the max recursion limit and samples for Caustics or even up the light samples for your back light to get a smoother look, there's a lot of noise in theses images, besides I always use BSDF, never bother with standalone SS Shader
