Thread: Stream from Input 1 while using DDR content in program out
    May 2013
    Clemmons, NC
    8
    I want to be able to stream our church service using only my Input 1 audio and video. Meanwhile, I would like to use the DDR content with audio to send to program out for content on the projection screen during the service. Is it possible to do both things at the same time?
    Oct 2012
    Nottingham, UK
    182
    What model TriCaster? If you have anything from the past few years this is easily acheiveable using the second mix and aux busses.
    Central Control - MIDI, OSC and StreamDeck control for TriCaster and 3Play - centralcontrol.io
    May 2013
    Clemmons, NC
    8
    I am using a TriCaster Mini HD-4. I use the HDMI version. It is an older model with only 1 stream configurable. I set the output configuration for the stream as camera 1 and audio input 1. I can do this and get the camera feed on my stream, but I get no audio unless the camera feed is in program out.
