Thread: How to use TriCaster Mini HDMI front audio inputs
    Oct 2018
    San Antonio, TX
    30
    I have a TriCaster Mini HDMI and want to use the front audio inputs. I'm running the latest version of AE3. Can anyone help me to configure the Audio Mixer to use those audio inputs?
    Do I configure 1 of the 8 audio inputs in the Audio Mixer to 'go to' to those inputs?
    Here are some screenshots of the input audio configuration screens:
    Depends on if you want the Line or Mic inputs.
    Input 1 gives you access to the Line input.
    Input 2 gives you access to the Mic input.
    Note that aren't required to actually have to place Input 1 and 2 as those locations in the multiview or audio mixer, you just need to pick those Inputs under the Local group.
    Once you select these, there will be a second selection where you can choose the embedded HDMI/SDI audio or the analog Line/Mic audio. You can only pick one or the other, you cannot use both embedded and analog on inputs 1 and 2 at the same time.
    Oct 2018
    San Antonio, TX
    30
    Thank you, Kane, this worked great.
