Results 1 to 15 of 27
Thread: LW & Kitbash NeoCity
    there is no sanctuary....
    Mar 2004
    Rochester Hills, MI USA
    546
    Kitbash is offering the Neo City kit for free. Unfortunately I can't get either the FBX or the obj files to link the textures.
    Has anyone else tried this with success? I reloaded another kit from the FBX and it worked fine, so I don't think LW has changed. Tried both load scene and interchange.
    Thanks.
    Bill Carey
    3900X 3.79
    Win10 Pro 64bit
    32gig Ram
    AMD 5700XT 8gb 20.4.2
    LW 2020.02 x64
    Space Navigator
    Works for me. Textures need to be in the right path.
    Tim Parsons
    Near Beaverton, OR
    2,038
    I'm having the same issue as Carey w/ both the OBJ and FBX.
    The extracted file creates a KB3DTextures folder and I'm not asked where anything is when I import the FBX or open the OBJ in Modeler.
    What you have different Tim?
    The Big Apexx System:
    64GB
    May 2003
    Ohio
    1,290
    I had no luck with the images in the FBX/OBJ package. I went back and downloaded the .blend file option, immediately saving out a FBX from Blender. That FBX loaded into LW fine, with images.
    LW4, 7.5D, 2015, 2018, 2019, 2020 running portably on a USB drive.
    Active LW Development in 2020: DB&W | Deep FX | DPont | LWCAD | TrueArt | ...
    Near Beaverton, OR
    2,038
    Will give that a try tomorrow then.
    64GB
    Mar 2004
    546
    Thanks, that worked. Forgot I had even installed Blender. Not sure what path structure Tim used, but I wasn't able to figure it out.
    Bill Carey
    3900X 3.79
    Win10 Pro 64bit
    32gig Ram
    LW 2020.02 x64
    Space Navigator
    For OBJ check *.mtl file in case links are absolute instead relative and then put OBJ file in same folder where textures are in case it didn't ask you for textures on loading.
    RAM-Studio
    WS - Dual Xeon E5-2698v4/128GB/Win10x64/4xRTX 2080Ti
    Mar 2004
    546
    Quote Originally Posted by Lewis View Post
    I checked the mtl, the links are missing completely. After loading the native version into blender, exporting the fbx, loading into lightwave you can the export obj files and the links are included. Roundabout, but it works.
    Bill Carey
    3900X 3.79
    Win10 Pro 64bit
    32gig Ram
    LW 2020.02 x64
    Space Navigator
    Yeah if there is no *.mtl then it's normal that LW will not load textures, no app will since it's not written where is and what is the texture .
    as for FBX Lw 2018-> has two different systems of loading FBX, one OLD (just like regular loading models) and new Interchange version though interchange panel so maybe try both and see do they work same.
    RAM-Studio
    Mar 2004
    546
    There is an mtl file, it’s just missing the image links. Tried both ways loading the fbx, same result for me.
    Bill Carey
    3900X 3.79
    Win10 Pro 64bit
    32gig Ram
    LW 2020.02 x64
    Space Navigator
    Near Beaverton, OR
    2,038
    Yup, that worked.
    So I wonder what it is that Blender is getting right & LW et.al. aren't?
    64GB
    May 2003
    Ohio
    1,290
    Blender is only getting its own file format (.blend) right. I never bothered to check if Blender properly opened the OBJ/FBX package. I'm not at the computer to check now.
    I can confirm the OBJ is garbage because there are no image files referenced in the companion MTL file. Blender would not do any better opening the OBJ file.
    Maybe someone can try to open the FBX in Blender (or any other app).
    Near Beaverton, OR
    2,038
    Just opened the FBX that Blender created & seems fine. I'm so unfamiliar with it to do much, but the textures & geom all seem to be in place.
    64GB
    Registered User dlvphoto's Avatar
    Feb 2018
    Atlanta, GA
    43
    What path did you put the images in? None of the paths I've been able to figure out, including the ones I've found by examining the FBX files with a hex editor and trying the paths embedded in them works. What I'm seeing is that the new versions of the kits have an invalid surface type baked in that nothing outside of Max can understand.
    Near Beaverton, OR
    2,038
    Quote Originally Posted by dlvphoto View Post
    I'm not sure now several weeks later. If I was given an option from Blender, I saved it to a separate export folder I normally use. The FBX itself usually contains the image folder so when Open via Layout, that simply gets created in the same folder as the FBX.
    64GB
