Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
Thread: LW & Kitbash NeoCity
  1. #16
    there is no sanctuary....
    Mar 2004
    Rochester Hills, MI USA
    545
    I just tested a fixed fbx from kitbash, they said they’ll be updating the downloads in the near future to fix both the FBX and obj / mtl files.
    Bill Carey
    3900X 3.79
    Win10 Pro 64bit
    32gig Ram
    AMD 5700XT 8gb 20.4.2
    LW 2020.02 x64
    Space Navigator
  2. #17
    Registered User dlvphoto's Avatar
    Feb 2018
    Atlanta, GA
    43
    I'm pulling all 18 kits I own at the moment and will run through all of the ones that have been upgraded to the 4.0 builds. Sadly, about half of my kits are now "legacy" kits and won't ever see the upgrade, but I've already broken those out into workable objects, textured them for native and octane and integarted them into my libraries so it's not too bad. Still would love to have the new UV layouts though.
    Scott
  3. #18
    Feb 2018
    Atlanta, GA
    43
    I've tested the new downloads of NeoCities and Shangri La kits. Neither one are fixed so the images still don't link with the FBX. The MTL files for the OBJ versions are also still missing the image links.
    All that said, however, the new kits are pretty nice. Here's what the new surface layout and a VPR view of one of the buildings in the NEO Cities looks like. Took me about 30 minutes to surface the entire kit using ODTool's great little "PBR Importer" tool. I adjusted the bump strength to 20% and you have to move the opacity map from transparency to clip on *some* objects, based on what it's being applied to (the decals for instance).
Name:	Screenshot 2020-09-24 03.44.49.png
  4. #19
    Very nice!
    Tim Parsons
  5. #20
    Mar 2004
    545
    Quote Originally Posted by dlvphoto View Post
    Looks good! They didn't say when they were going to redo the files, so who knows.
    Bill Carey
    3900X 3.79
    Win10 Pro 64bit
    32gig Ram
    LW 2020.02 x64
    Space Navigator
  6. #21
    Feb 2018
    Atlanta, GA
    43
    Quote Originally Posted by Bill Carey View Post
    I'm tempted to see if I can clear enough time in my schedule after I deliver the two book-cover projects I'm working on to write a quick FBX analyzer to show things like image links and surface attributes in python* and send it to them.
    "Here, export your kits. Run this and LOOK!!!! at the image and surface references. Are they correct? No? Then fix it!"
    May even see if it'd be possible to add the ability to edit the FBX refernces in place and export a new fbx file from the script but that's down the road. Reading an FBX file is one thing. Writing one? That's a whole other kettle of chrome teapots.
    (when/if I do, it'll be on my github repo so anyone can take a look, use it, modify it, whatever... open source is fun, yo!)
    Scott
  7. #22
    Mar 2004
    545
    Scott
    They do know, they sent me both the fbx and the obj with the new mtl file, both worked fine. Just a matter of them running and uploading updates. I saw some other people asking, so one more couldn't hurt, maybe speed the process up. I just told them I'm not buying until they are fixed. (Which is a shame, missed a good sale!)
    Bill Carey
    3900X 3.79
    Win10 Pro 64bit
    32gig Ram
    LW 2020.02 x64
    Space Navigator
  8. #23
    I emailed them to ask if the NeoCities updated files were online yet and they said yes. However, I still can't get the OBJ file to load the textures automatically. It's still asking me for the location of every texture file when loading the obj.
  9. #24
    ack ack Markc's Avatar
    Feb 2006
    England
    1,638
    Wow just checked out this website.
    Some cool stuff at reasonable prices.
    Mac Pro (2010) OSX 10.14 RX580 Pulse LW2020 CSculpt NMotion
    (plugins: LWCad 2020, TFD 1443, Syflex 2018, StarPro 2020, ExrTrader 2020, Ubercam 2.0, Daz Mocap, DP Light 2020, Quadpanels 1.5)
  10. #25
    Mar 2004
    545
    Quote Originally Posted by ELinder View Post
    It's looking for the images in a particular folder, make sure you unzip it and load the .obj file as it sits. After they load you can save them to an object folder and rename the texture folder to images, should find everything.
    Unfortunately LW will only set up a couple of the images. You'll have to go though and hook up the normal map etc. If possible use FBX / interchange, it sets up the surfaces as PBR and names the them so you can change all like named at one time.
    Bill Carey
    3900X 3.79
    Win10 Pro 64bit
    32gig Ram
    LW 2020.02 x64
    Space Navigator
  11. #26
    Feb 2006
    England
    1,638
    FYI Kat has just released a new video on Liberty3D for bringing Kitbash into LW.
    https://www.liberty3d.com/2020/10/pr...o-lightwave3d/
  12. #27
    I did unzip the file without changing anything. When I load the obj it asks me for the image location (which is the same as what's written in the path in the mtl file as far as I can tell). Even after pointing LW to the correct image folder it still asks for the location for every single image instead of looking to the folder I just pointed it to. I'll try the fbx version.
