Results 1 to 9 of 9
Thread: NDI video color band
    May 2020
    Canada
    12
    I'm using Scan Converter on one computer as NDI source, and Studio Monitor to check the video quality. I happened to run a monitor gray scale test on the source computer, which basically is a grayscale gradient image. (http://www.lagom.nl/lcd-test/gradient.php). It looks smooth on the source computer, but in the Studio Monitor, I can see some color bands in the image. Is it normal? Is this something to do with the color depth?
    I attached a screenshot. Hopefully it is visible here.
    I took that image, ran it out of NDI Test Patterns into NDI Studio Monitor and then did a screen capture. The grabbed image in a paint program shows the same values for R, G and B in every location that I tried which tells me there is no color in the image, only grey.
    May 2020
    Canada
    12
    Sorry I don't quite follow what you were doing. Which picture did you took? Both the gradient picture from the website in my first post and the attachment picture show colors changing from black to white. How do they have same RGB values?
    But I did try your way, which I took a screenshot of the original gradient picture and fed it to the Test Pattern then into the Studio Monitor, and now the color bands don't show up. Perhaps it is a issue of Scan Converter?
    Maybe I didn't make myself clear about the "color" band. The variation of colors in the original gradient picture from the website looks really smooth, but in my attachment, you can find some not too obvious but still noticeable rectangle bands.
    Thank you.
    May 2020
    Canada
    12
    Sorry my bad. Now that it is "grayscale" gradient image, it should be gray. But the bands do exist.
    Aug 2015
    london
    296
    Quote Originally Posted by slcf2003 View Post
    Converting a Ramp pattern to RGB then to 8-bit YUV can lead to the sort of banding you are seeing.
    If you generate a ramp natively in 8 bit YUV in NDI, it can be smooth.
    May 2020
    Canada
    12
    Sorry for the late reply. I don't know much about the pixel format. How can I generate a ramp in YUV in NDI?
    May 2020
    Canada
    12
    May 2020
    Canada
    12
    I'm also having the same issue in UE4, can you take a look if possible? Thank you.
    https://forums.newtek.com/showthread...th-NDI-for-UE4
    Registered User roddyp's Avatar
    Sep 2017
    UK
    60
    As Kane says, there's no "color" banding here. What I do see is luma banding - caused by the luminance of the pixels not smoothly changing across the ramp image.
    I think this is just an artefact of NDI's lossy compression. You can see a similar thing by selecting the "Ramp" test pattern with NDI Test Pattern Generator, then viewing that in Studio Monitor. It's quite noticeable with the "Color Ramp" test pattern in the darker areas, too.
    The effect is probably worse if you're using scan converter to grab an image displayed by another application, as there's probably extra rounds of gamma and/or colourspace conversion happening. When you're working in 8-bit colourspaces it doesn't take much to introduced these kinds of artefacts.
    The second images from Unreal Engine are a lot worse, with a serious lack of dynamic range in the shadows. That's definitely not just NDI artefacts.
