Results 1 to 15 of 29
Thread: Elven Scout
    Elven Scout
    It all started last weekend with an Elven type helmet play session.
    My friends suggested that I make the whole character.
    I made this over the last week. Inspired by many ideas and LOTR. Typical fantasy elf......
    Thought I would share.
    Modelled with LW 2020.
    Regards, Jet
Name:	Elven Scout_02_Sml.jpg
ID:	148354   Click image for larger version.
Name:	Elven Scout_03_Sml.jpg
ID:	148355   Click image for larger version.
Name:	Elven Scout_04_Sml.jpg
ID:	148356   Click image for larger version.
Name:	Elven Scout_05_Sml.jpg
    May 2012
    Virginia
    600
    Beautiful work! I really like the texture on the green cloth and the detail work on the metal pieces. Just a really gorgeous piece.
    there is no sanctuary....
    Mar 2004
    Rochester Hills, MI USA
    546
    These forums need an amazed button, wonderful!
    Bill Carey
    3900X 3.79
    Win10 Pro 64bit
    32gig Ram
    AMD 5700XT 8gb 20.4.2
    LW 2020.02 x64
    Space Navigator
    Frequenter
    Sep 2003
    Munich
    529
    Really, really beautiful!
    Jan 2011
    Seattle
    448
    Great design! Lots of meaningful details, and little superfluous nonsense. The way it should be.
    Near Beaverton, OR
    2,038
    Quote Originally Posted by Jet3D View Post
    Regards, Jet
    Wow.
    Was this entirely from scratch with LW? Were some assets from prior work is what I'm wondering? If completely from scratch, I want to know where you get your coffee or tea as the case may be.
    The Big Apexx System:
    64GB
    Very nice work! I really like the painterly backdrops. They give an interesting contrast for depth. It would be nice to see the wires for this as well.
    Aug 2006
    Eureka, CA
    7,099
    Excellent.
    shrox www.shrox.com
    Heavy Metal Landing
    Quote Originally Posted by Nicolas Jordan View Post
Name:	ES_Part Mesh02.jpg
ID:	148373Click image for larger version.
    Hi guys,
    Sorry, but as you can see, I have frozen the nurbs resulting in a heavy wire.
    Hi guys,
    Thanks, I'm curious, is there a particular reason that you freeze the nurbs/subpatch surfaces? Is it because you would normally hand off a finished model as polygons so it keep the mesh accurate when brought into other 3d programs? If I'm keeping things in Lightwave for rendering in Layout I always keep the nurbs/subpatch in modeler to allow for a lighter model that's easier edit later if needed and let Layout do the tessellation to polygons.
    17,397
    Isnīt freezing better for faster rendering than having to deal with the freezing that must take place before rendering in layout anyway?? since this is static rendering..there is no need to animate it either.
    But it could be as you say..he also provide it as freezed models for print etc, but then again he could keep a version non freezed...Unless there was a specific need to have it freezed for the actual modeling process.
    I don't think it would make any difference with rendering speed either way since it's essentially the same thing for the render engine. Using Lightwave since version 6 I have never had a reason to freeze models in modeler unless I needed an accurate model in another 3d program or render engine. I'm guessing there was a time before Lightwave 6 when users would have to manually freeze models in Modeler before loading them into Layout?
    17,397
    You do now that layout has to freeze any subpatch before rendering? and the heavier the subpatch level there is, the longer it takes.
    Now ...an already freezed model in layout doesnīt have to freeze again in layout, thus it should be faster to render.
    Try with 500 000 landscape that is subpatched to that level in layout, vs a freezed one in that level.
    All this may be only be tech trivia though, and not the actual reason for Jetīs approach of it.
    I would rather guess that he might have used intricate detailing, booleans and such ..which makes it much harder to work with subpatched non freezed nurbs like surfaces.
    All that aside, great work from Jet, and I also like the background painterly look with the cleaner foreground model.
