Results 1 to 14 of 14
Thread: Enable transparency for M/E buses
    Sep 2016
    Ukraine
    16
    Very often 4x DSK is not enough to show all necessary CGs from buffers and GFXs, 4 is maximum currently.
    I would be great to enable transparency for M/E buses.
    It will allow to combine up to 8 sources in one ME and then assign this ME as DSK source to show 8 layers using only one DSK.
    Currently ME getting with black background once I turn on any KEY layer or switch ME from MIX mode or mixing A B layers in ME.
    Please enable transparency for M/E buses, it will help a lot for many Newtek customers.
    Aug 2016
    USA
    562
    Try putting an M/E into an M/E
    Sep 2016
    Ukraine
    16
    Quote Originally Posted by Stream View Post
    Tried - it does not helps, as another M/E also getting with black background once I started to mix it with second transparent source.
    Macro Titan JonRaidel's Avatar
    Sep 2009
    Los Angeles, CA
    222
    you can use the liveset '4 layer set' to create an M/E with 8 layers, all of them hold transparency.
    you may need to re-enter an M/E as Layer D to do a dissolve from sources, and they you effectively are using 11 keyers ontop of a P/P ME.
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    Panasonic HDX 900 Cameras
    NDI Connect Pro
    Graphic Outfitters ScoreHD
    Graphic Outfitters Scorebridge
    Livetext 3 w/ LT [Scoreboards 2]
    Sep 2016
    Ukraine
    16
    Is it working that on your TriCaster?
    In my system (TC1 with PremiumAccess) M/E getting non-transparent as soon as I switch it to '4 layer set'.
    M/E also getting non-transparent in default mix mode when I do 1% transition progress.
    In mix mode the M/E also getting non-transparent when I turn on any of 4 keyers with transparent source.
    Sep 2009
    Los Angeles, CA
    222
    I see what you are trying to do. you want to add just an ME onto DSK to show all the GFX sources. thats not how this will work. the last layer on the M/E is going to need to be full video.
    you are going to have to use an ME on the program row or use re-entry to get a P/P to take/fade in your last layer.
    for example:
    M/E2 on Program.
    M/E2: 4 Layer Set. A:Buff1 B:Buff2 C:Buff3 D:ME1 KEY1:Buff4 KEY2:Buff5 KEY3:Buff6 KEY4:Buff7
    M/E1: MixMode
    now you will switch video sources using M/E1 but M/E2 will stay on program giving you all your graphic sources.
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    NDI Connect Pro
    19,868
    Of course you can blow a layer on a keyable background color and key the entire M/E; not an ideal solution, but often good enough.
    Sep 2016
    Ukraine
    16
    Thanks for advises guys, idea from JonRaidel is really wonderful.
    Chromakeying is also can be applicable somewhere.
    In my current case I want to use it in TC410Plus that have only two layers per M/E + two KEY. 4x sources in total per M/E, not so much.
    I’ve planned to combine with one M/E 2x GFX1+GFX2+Buffer1+Buffer2 and to assign it to DSK1. Rest 3x M/E I need for a VirtualStudio.
    Basically I’ve placed this thread as a feature request to implement “M/E With transparency feature” in future SW releases as I don’t see any physical and logical limitations to implement it.
    It would be great to pass this request to R&D guys for review.
    I’m sure, this feature could be useful for many TriCaster customers.
    Bloomington, IN
    1,636
    I second the feature request, it seems like supporting alpha all the way through the M/E would be really useful. Yeah, you can work around it but why should you have to.
    -Jeff
    My TriCaster Blog
    TriCaster Tally Lights
    Gear Used: TC1, NC1 I/O, TC 460, TC Mini 4k.
    Sep 2013
    Atlanta
    357
    Third the request
    Jun 2006
    Chicago, IL
    664
    I'll pile onto this, too.
    Fritz Golman
    Sep 2009
    Los Angeles, CA
    222
    does the TC410 not have the 4layer effect in its livesets as an option?
    Quote Originally Posted by RomanBilous View Post
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    NDI Connect Pro
    The TC410 and TC410 Plus have 2 Layer and 2 Keyers per M/E. The TC1 is the model where you get 4 Layers and 4 Keyers per M/E.
    Apr 2017
    Salem, OR
    10
    Adding my support for the feature request.
    Grant Bachman
    IT & Video Engineer
    Capital Community Media
    Sent from 💻
    TC1, NC1I/O, 3P1
