Results 16 to 22 of 22
Thread: LW 2020.0.1 Mac numeric input boxes problems?
    8,365
    Usage of tablet is very important factor which should be mentioned in the bug report..
    Are you switching Input Method in options?
    I don't have a tablet, so at least in my case that's not the problem. I do have a Logitec Bluetooth mouse, but I've never had this problem in any other program.
    Erich
    7,227
    I'm reasonably sure this stems from how Newtek is setting up the LW UI / Qt input focus relationships. This isn't new, Mac LW's UI historically has had problems in the area of window and UI gadget input focus, long before Qt entered the picture -- that's why I suspect the problem's more on the app coding side than the Qt side.
    I've tried several times unsuccessfully to screen record this problem. However, every time I go the other program - in my case Quicktime - to start the screen recording, when I go back to Lightwave, the problem has disappeared and all is working properly again. Well, at least now I know what to do to reset the bug.
    Erich
    7,227
    Quote Originally Posted by ELinder View Post
    You need to try and figure out the "trigger sequence" and then begin screen recording _before_ issuing the trigger sequence to make the problem appear. Switching away to another (gfx?) app then back to LW likely forces LW back to a "input-chain-valid" state, so you need to capture the issue without switching away until after you've captured it.
    ack ack Markc's Avatar
    1,650
    Erich
    Is this in 2020.0.2?
    Mac Pro (2010) OSX 10.14 RX580 Pulse LW2020
    (plugins: LWCad 2020, TFD 1443, Syflex 2018, StarPro 2020, ExrTrader 2020, Ubercam 2.0, Daz Mocap, DP Light 2020, Quadpanels 1.5)
    8,365
    Hotkey screen-recording app..
