Results 1 to 10 of 10
Thread: How to bring in a YouTube Live stream as a input source on TC1 ?
    Jun 2018
    Baton Rouge
    22
    Is there a way to bring in audio & video from a YouTube live stream that is opened in a browser on my TC1 computer?
    Or can this be done over the network with another computer having the YouTube live stream open?
    Thanks,
    Jeff
    Thanks,
    Jeff
    TC1, TC1SP Control Panel, Panasonic AW-HN130 Cameras
    Jun 2006
    Chicago, IL
    632
    You can use VLC player set to output NDI streams to reflect YouTube content. Or use Scan Converter and go to a YouTube page.
    I've used both for this purpose often although the VLC solution is the cleaner of the two.
    Fritz Golman
    Jun 2018
    Baton Rouge
    22
    This can be done using the TC1 hardware? No problem with installing VLC on the TC1?
    Thanks for the information.
    Jeff
    Thanks,
    Jeff
    Jun 2006
    Chicago, IL
    632
    No, those are on an external PC sending NDI over network to TC1.
    Fritz
    Jun 2018
    Baton Rouge
    22
    Is this available on a mac? The TC1 is the only windows that I have.
    VLC looks to be different on my mac pro. Example: I don't see an "output" option on the mac VLC in order for me to choose NDI.
    Thank you
    Thanks,
    Jeff
    Jun 2006
    Chicago, IL
    632
    I can't say if VLC supports the NDI plugin on a Mac as I don't have any. However, I know you definitely can run Scan Convertor on a Mac.
    Fritz
    Jun 2018
    Baton Rouge
    22
    Ok great - I'm getting video with scan converter, but no audio. I've checked the audio options on the TC1. All looks fine. Any thoughts?
    I appreciate your help.
    Jeff
    Thanks,
    Jeff
    Jun 2006
    Chicago, IL
    632
    Sorry, I have only passing knowledge of Macs. Maybe Kane or someone that has a Mac and Scan Convertor can address this.
    Fritz
    PS I did confirm that there is no VLC Plug In for Macs, FYI.
    There is not a VLC NDI plug-in for OSX. There is Scan Converter for OSX, but you might need to try out a few different ones to see which performs best on your Mac system. NewTek, Sienna, OBS and vMix all make scan converting type tools for Macintosh.
    Sep 2013
    Atlanta
    339
    The NewTek mac scan converter works perfectly for pulling in web sources on a mac and shooting them to the TC via NDI. To get audio there as well, you need to download, install and configure VB Audio Cable.
    We use this combo for Zoom, YouTube, pretty much anything web-based that we want to pull into a program.
