Thread: SKYPE TX & TC1 not connecting
    Sep 2017
    Australia
    7
    I've followed the NT instructions and all goes well, I have 2 channels showing in SKYPE TX (although there not labeled Channel 1 & 2, just the IP address of the TC-1 ). I click on the SKYPE connection and I get the following alert:
    "To access this channel, you will need to upgrade to a latter version that supports the newer channel version"
    Upgrade What? - TC-1, SKYPE TX, Windows.
    I've installed the latest version of TC-1, I downloaded the latest version of SKYPE TX. Do I need to update Windows as well or am I missing something?
    EDIT: Latest version of NDI Tools also installed on both TC-1 and system running SKYPE TX.
    Jan 2018
    Winter Park
    526
    On one of the tabs once you connect There is usually a section for you to click upgrade and it will update the talkshow portion of the software on the tricaster I believe. From time to time I get prompted to update that software which is outside of the Skype TX on the laptop and the tricaster updates.
    Can you tell use what version of Skype TX Control you are running?
    This message appears after you connect to the channel? An icon with an error pointing down should appear at the bottom of the channel which will allow you to update, sometimes it take a little bit for it to check that Microsoft has released a new channel update.
    Sep 2017
    Australia
    7
    Quote Originally Posted by stp_productions View Post
    I don't seen to have the tab with the upgrade option. I did notice the "how to" NT video had it, but nope not there.
    SKYPE TX version: 2.19.505.1
    Yeah after I click on the "Channel" button in SKYPE I get this message, I get no error icon pointing down. Its almost like I'm using an old version or something.
