Results 16 to 17 of 17
Thread: Can My Tricaster Mini Inputs Pass Through 1080P NDI?
    19,703
    So, having discussed this in Engineering, I'm pretty confident that HDMI works as I described (negotiating with the source as required), while NDI supplies (and can record, at input) the full original format (including 4k) regardless, (bandwidth and other resources allowing, of course).
    Hmmm, it is a Canon XA20
    That camera says it supports up to 1080p59.94, so to make it work on the Mini HDMI, you have to make sure it to 1080p29.97 (it looks like in the manual, it might be a PF mode). If that is the case, then set the HDMI input on the Mini to 'HDMI Auto (Computer)' that it also works in a progressive mode.
