Results 1 to 9 of 9
Thread: DP open image denoiser - use a different normal image ?
    geo messy madno's Avatar
    Feb 2009
    Germany
    846
    I hope I can explain:
    Testing DP open image denoiser in LW 2020 - so far quite impressed.
    But, have a render that seem to loose details because of noise in the normal pass.
    I can't increase the AA samples much more because of render times.
    But I can render the normal pass only (disabling all lights etc.) with super high AA in a few seconds.
    Normal pass with low AA samples:
    I assume the Intel denoise algorithm interprets some of the fuzzy lines as noise.
    Normal pass with high AA:
    The idea is, to give the denoiser the below normal pass, to see if it works better.
    But I don't know if this is possible at all with DP's implementation of the plugin.
    So far I just can enable it in the Image filter and it denoises what it gets from the current active render.
    Question is, can I feed the alternate normal image somehow into it?
    San Jose, CA
    6,957
    Hmm...what happens if you load the rendered normal image file back in as an image buffer and feed that as normal buffer input?
    @Denis (as he'll likely read this thread), something's also up with MacUB version of OpenImageDenoise_2018.plugin, getting "Cannot open external plugin file" + 0/1 plugin dialogs on attempted add in LW2020.1UB64 (10.13.6). Same package/binary loads fine in LW2019.1.5UB64 (same machine).
    I'll repost in separate thread if easier for you to track.
    John W.
    May 2006
    France
    4,183
    ...something's also up with MacUB version of OpenImageDenoise_2018.plugin, getting "Cannot open external plugin file" + 0/1 plugin dialogs on attempted add in LW2020.1UB64 (10.13.6)...
    Sorry I didn't installed LW2020 on a Mac before,
    I can confirm that the tbb library issue is still there on the MacUB,
    so you will need to replace the libtbb.1.0.0.dylib in Bin folder
    by mine included in the zip, like for previous versions.
    I will report this and modify the erroneous readme file.
    Thanks for report,
    Denis.
    Mar 2018
    Perth, Australia
    131
    Quote Originally Posted by madno View Post
    Yes this is possible. However, you need to do it in 'post'. So when you rendered your beauty pass, albedo and normal passes, you open a new layout window and only use the denoiser on the rendered images like this:
    Basically you use Lightwave as a GUI for the denoiser. I use this method to control what passes I want to have denoised. You can, for example, render a fairly noisy Diffuse_Indirect pass and have only that pass denoised before you comp everything into a beauty pass. Saves a lot of render depending on situations.
    May 2006
    France
    4,183
    ... can I feed the alternate normal image somehow into it?
    Of course you can,
    first use the EXR format for saving the Normal,
    because you need to keep the negatives values of the Normal channels,
    a PNG has 0-1 clamped values,
    you can load the separate normal pass in an Image node,
    connecting it to the Normal input of the OIDN node,
    but disable Pixel Blending in the Image node.
    Denis.
    Feb 2009
    Germany
    846
    Many thanks guys and dpont. Based on the tests I would call OIDN a game changer. Used it in Blender and was already impressed and am now the same in LW.
    Mar 2018
    Perth, Australia
    131
    You might want to check out this thread as well:https://forums.newtek.com/showthread...ghlight=albedo
    This handles reflected and refracted normal and albedo passes. Works brilliantly on glass and metal surfaces (which normally are pure black in the Normal and Albedo pass). Just wished LW had this capability out of the box (made a feature request for this). DPont made this possible. It's just a little bit more work to set it all up.
    Feb 2009
    Germany
    846
    Thanks,
    will definately have a look as window glass and refraction creates a mess in GI my test at the moment.
    San Jose, CA
    6,957
    Quote Originally Posted by dpont View Post
    Thanks for report,
    Denis.
    Thanks Denis! That fixed the issue as expected!
    John W.
