Results 1 to 10 of 10
Thread: LW 2020. 0.0.1 Environment light noisy
    Aug 2006
    UK
    251
    I've tried increasing light samples, increasing camera samples. Everything I try I have to increase a lot to get a clean enough image for animating. I have GI turned off, but Env. Light still noisy, the fibre fx has bad fireflies, I like the Environment light as it brings more realism with an hdri map. Anyone got any tips for cleaner renders with faster times. At the moment it's taking around 5mins to get a passable image but not really good on the hair. Thanks in advance.
    Pessac
    5,193
    How many zeroes?! 2020.0.0.0.0.0.0.0.0.0.0.0.1? What's in your HDR, how big is it, does it have small hotspots?
    B
    LightWave 3D Trial Edition
    Aug 2006
    UK
    251
    Lol sorry that was meant to be 2020.01. Dunno what happened there. I'll check what size it is, but tried other hdri's and still noisy. Don't mind cranking it up for stills but for animation it's just too long rendering, so gone back to normal lights without environment light. Will keep tinkering.
    Do you have principled glossy material(s) which has 50+ percent roughness in your scene ? If yes, then try lower roughness like 30% or so.
    RAM-Studio
    WS - Dual Xeon E5-2698v4/128GB/Win10x64/4xRTX 2080Ti
    Aug 2006
    UK
    251
    Quote Originally Posted by Lewis View Post
    I'll double check and try that thanks.
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,612
    You can also enable despike; I usually have it set to .2 instead of the default.
    That should take care of most of the fireflies. I use an environment light with FFX and don't see any fireflies.
    To reduce the amount of noise using FFX, don't use solid black (0,0,0) as a shadow color. I use (.06,.05,..06). And don't forget the shading overrides - It seems that all the hair shaders are now classified as dielectric materials, which means you can override the refraction samples for it to something higher( like 3-4) on a per material basis.
    My Scripts for Lightwave
    Aug 2006
    UK
    251
    Great tips, will definitely try that thanks.
    Aug 2006
    UK
    251
    Tried the tips above, but still have fireflies/noise on the hair. Just cannot get rid of it unless I were to crank camera samples to silly amounts. Will have to keep tinkering but running out of ideas now. Maybe it's because the characters hair is black.
    Feb 2009
    Prescott, IA
    1,612
    can you post the scene, or a simplified version of it that exhibits the problem?
    Aug 2006
    UK
    251
    I just realised I set despike wrong. Was looking on my phone and thought you wrote 2, but in fact it's point 2. Will try that. I notice some hair surfaces render better than others. I think there's about 3 different surfaces for hair.
