Thread: Apply LUT ?
    2,350
    Apply LUT ?
    For 2020 :
    Any way to apply a LUT .cube to the VPR view via node pixel filter ?
    They do load in the Colour space options for Display but don't look correct
    For 2015 : CAn this be done via CC tools of Dpont tools ?
    May 2006
    France
    4,183
    This is possible with the last node addition in DP Filter,
    in DP Filter/Filters tab, the Color Space node works with color and/or scalar input,
    you can load a Color Table file where you want, can be also saved independantly.
    Pixel Filter node editor has also a "VPR Only" option,
    in this case node setup is ignored in F9/F10 render,
    but this node uses the same ColorSpace conversion than Lightwave,
    so not sure result would be different from "Display".
    Denis.
    May 2006
    France
    4,183
    I fixed several issues in my first bad implementation of Color Space node.
    Gerardo mentioned an issue with 3D Luts color tables loaded in LW Color Space system,
    rather working as 1Dx3 Luts.
    https://forums.newtek.com/showthread...=1#post1557398
    Denis.
    Jul 2017
    Middle of nowhere
    256
    Merci beaucoup. I don't think anything you do is bad.
    2,350
    Denis.
    Thanks Denis, I will give this a go
    Denis.
    Great. I will read that.
    Where is Gerardo these days? this it the type of thing that might perk his interest.
    oh, thought just occurred to me, with the prolific updates and bu fixes to your tools, perhaps have a Dpont plugin in LW that allows for updates to all DP plugins with one press?
    Have you used Directory opus, with its updates panel? https://www.gpsoft.com.au/help/opus1...e_Checker1.htm
    Maybe this feature is unlocked with a donation ?
    cheers
