Results 1 to 8 of 8
Thread: Uv looks fine in modeler but will not render
    Registered User ianay's Avatar
    Sep 2004
    glasgow
    152
    Ok, I dont often use UV maps but recently I thought I will jump back into it. So I gave it a go with a 'simple' sphere.... But...
    I built this test UV and it looks fine in modeler and in Layout, then when i go to VPR or render?
    No good... I have no idea what the issue is. Heres some screen shots of it looking fine then VPR mess
    I realise this is probably an easy fix but Ive been away from UVs for a while
    Cheers for all help
    1,785
    Probably be easier if you could package the scene and post as an attachment. Could be any number of things such as using a wrong UV or a map that's errant. Is it a png by any chance?
    The Big Apexx System:
    64GB DDR4-2666
    Sep 2004
    glasgow
    152
    Not a png.. and surely if it was wrong UV or map then it wouldnt show on modeller or layout (before VPR) ?
    Heres scene file, with object and image
    thanks for help
    Still...Absolute Amateur scallahan1's Avatar
    Aug 2012
    Salem, NH
    209
    Loaded into 2020 and it looks perfect in VPR and Render. Don't have 2019 installed any more.
    Barcelona
    1,733
    ianay, it renders fine here too.
    Salut!,
    Allabulle.
    Sep 2004
    glasgow
    152
    strange...I have 2020 also and im getting exact same issue with 2020...
    1,785
    Just took a look in 2019 in both Modeler & Layout. VPR & F9 rendered fine. Look into your vid drivers I guess.
    64GB DDR4-2666
    Ohio
    1,106
    If not the video drivers, try backing up your LW configuration, blow out the current configuration, and see if there's improvement. (Restore backed up configuration if nothing improved)
