Page 1 of 7 123 ... LastLast
Results 1 to 15 of 92
Thread: LW 2019.1.5 vs LW 2020 render time comparison
    I loaded up the Dragon_CopperVerdigris.lws scene from the LW 2019 content and rendered in 2020 at the default settings it loaded in at. I thought it was taking a bit long to render out so I loaded it into 2019 to see what the render time difference was. To my surprise this scene actually renders almost twice as fast in LW 2019.1.5 than it does in 2020. This scene has no GI and uses a Environment Light so it should be a fairly direct comparison. Does anyone know why LW 2020 is much slower to render this scene?
    I have attached screen grabs below.
    I also noticed it, for this LW2020 is not very useful for me. It is Enviro Light that slows down render. turn off them and rendering times will be like in LW2019.
ID:	147743Click image for larger version.
    Enviro.rar
    2D/3D Specialist
    http://www.render-up.com
    Win10 64bit, Dual Xeon E5-2696 V2 @ OC 3,3 GHz per Core, 64GB RAM, 2 x GeForce GTX 1080 Ti
    Quote Originally Posted by artzgo View Post
    Enviro.rar
    So does than mean that the environment light itself is somehow changed or fundamentally different in LW 2020? It seems to produce the same result but just takes much longer to render things. I knew GI had changed but this scene doesn't use GI at all.
    Yes, now BackDrop lighting from the Effects tab doesn't work without Enviro Light. And the use of Enviro Light gives a lot more noise and significantly extends the rendering time. In my opinion, this is a very weak solution.
    2D/3D Specialist
    May 2003
    Europe
    278
    The env light is listed as an updated feature in the 2020 docs and someone mentioned that deleting it in old scenes and then adding it again, improved render times. Maybe it is env light 2.0? From the 2020 docs: The Environment light is used to add light from the backdrop for a scene. It is now in new scenes by default with a distant light
    Quote Originally Posted by Free4Ever View Post
    Based on that it seems like it would only render faster if you delete and re add the environment light because a new light would come in a default settings which are usually much lower so you would get a better render time but lower quality.
    16,793
    Hmm..I use backdrop for lighting GI often, I hope this new method with environment light doesn´t make things slower, or noiser..we´ll see.
    Unfortunately, my tests show that it is much slower, so I probably will not update from LW2019 to LW2020
    2D/3D Specialist
    I tested out a couple other scenes from the content including "Hero" and "RC_Helicopter" Both of which have environment lights and get better render times in LW 2019 vs 2020. I also tried a scene without an environment light in it "Bowling Simulation" which actually rendered just slightly faster in LW 2020.
    all my packshots scenes and I have a lot of them, they render much slower in LW2020. I reported this problem but I get the impression that it was ignored.
    2D/3D Specialist
    Yes, if it's not considered a bug and doesn't have content with it then it will likely be ignored. Hopefully it was passed along to the dev anyway. I would think that all this stuff was known in beta. It's pretty hard not to notice it if any amount of testing was done.
    Upon doing even more testing between 2019 & 2020 on scenes with the environment light I found there may actually be less noise in the 2020 version although you may get an increased render time with no apparent reduction in the noise in some scenes and others will show reduction in noise with very little increase in render time. There must have been lots of changes under the hood leading to different variations in render times and quality pay off for the longer render times.
    Aug 2016
    a place
    2,354
    Quote Originally Posted by Nicolas Jordan View Post
    what about in cases where no content is needed to reproduce an issue? is this a blanket response to all submissions without content?
    True some bugs don't require content and are just a sequence of reproducible steps. That comment was just based on my previous experiences over the years. If you discovered what you think is a bug go ahead and submit the worst thing is that they will ask you for more info.
    I would wait until the first update of 2020 before making any final judgments. There are also a few other issues that need to be addressed as well that make it difficult to use in production. I would contact support if you need a trial extension too.
