Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 92
Thread: LW 2019.1.5 vs LW 2020 render time comparison
  1. #46
    Aug 2016
    a place
    2,353
    Quote Originally Posted by Marty3DGuru View Post
    The 2020 glass material has not been set up correctly hence it doesn't look as good.
    should they not be setup correctly producing similar results to have a true comparison?
    - - - Updated - - -
  2. #47
    pass:sword OFF's Avatar
    Russia
    1,087
    Quote Originally Posted by Nicolas Jordan View Post
    Since there is no "sample backdrop" in LW2020 you are now required to use an environment light in place of that to get the same or similar result as using "sample backdrop" in previous versions.
    Env on. Time 8m 46s - 22 seconds more than without Enviro light, but still faster than lw 2018|19.
    Link to benchmark scene archive:
    https://yadi.sk/d/kjBhCtLZJzbX0A
  3. #48
    Quote Originally Posted by OFF View Post
    There is something different about your scene in 2020 as gar26lw indicated above. It may be that the environment is not be reflected on the surfaces of the items in your scene in 2020.
  4. #49
    I have noticed that loading a scene from 2019 and earlier into 2020 has lighting issues...pretty much have to replace any lights in the scene with 2020 lights...Dont know why this happens..but it was driving me mad while I was trying to check new skin shaders and hair from my Frozen project in 2020 and the lighting was just bjorked.
    Though honestly, it would have been nice if they had kept the option to use a backdrop as gi source because when you just want a simple gradient, it was fast.
    Rob Depew
    Modeler/Animator/Editor
    Web Portfolio
    My Patreon
    YouTube
    Lightwave3D 2019, RF10, Gaea and more..
    Threadripper 32 core , 48gb, GTX-1070
    Asus 752vt i7 2.6 x 4, 48gb, GTX-970
  5. #50
    Aug 2016
    a place
    2,353
    yes i thin he backdrop needs reverted
  6. #51
    Mar 2018
    Perth, Australia
    133
    Another issue with the Environment Light and Backdrop is that the intensity of the backdrop is now linked to the intensity of the light itself. Meaning that when you increase the strength (lx) of the light, the backdrop gets brighter too. In 2018 that was not the case and I liked that as it gives you much more artistic control. If you wanted the acxtual backdrop lighter, just ramp up the opacity in the Environmental Texture.
  7. #52
    Aug 2016
    a place
    2,353
    yeah another good point. i guess a case of engineers changing things without consideration or creative usage and bending the rules to gain a desired if not physically accurate outcome?
  8. #53
    England
    6,004
    The reason this was changed, was so we didn't have the raytrace and env light ball ache changing PER MATERIAL!
    Tonnes of users never even realised, even to this day, that if you used the env light, you HAD to change ALL material's tracing to "raytrace only" rather than raytrace and backdrop.
    I am really glad they made this change. If you want to change the backdrop brightness separately from the light, then add an env light that is visible to backdrop, but doesn't affect specular or diffuse. There you go.
    Desk Work:
    Desk Home:
  9. #54
    Aug 2016
    a place
    2,353
    I think most knew of that issue, if they read the forums.
    why not a global switch and leave background as is?
    and/or default materials to optimal setup ?
    either way, I think the old backdrop system is warranted.
    regarding the workaround: it creates a more convoluted workflow. I get why they did it and it is good for the fix but I do think that a reduction in functionality is best avoided while fixing things.
    maybe Dpont can do something.
    Small changes to workflow are a huge thing in aggregate. Something that needs to be given great consideration by the dev team.
  10. #55
    Mar 2018
    Perth, Australia
    133
    I totally agree with the Raytrace + Backdrop vs Rayrtace Only thing... That was really tiresome to change all the time and is a logical thing to change.
    I tried to achieve this but wasn't able to any result. How do you 'add an env light that is visible to backdrop, but doesn't affect specular or diffuse'?? I can create an env light that does not affect spec and diff but as soon as I add a second env light that needs to sample the Env.Texture, it automatically overwrites the previous backdrop with a bright version of it?
    Can you share a setup how this is done?
    As a side note, even if you could do this, adding a light and setting it up as such is a lot more work than separating the brightness of the light and the beckground. If I need to change my background, I need to change it twice in this setup. Not very intuitive. Anyway, looking forward to your solution as it really bothers me.
  11. #56
    Quote Originally Posted by peebeearr View Post
    ...I tried to achieve this but wasn't able to any result. How do you 'add an env light that is visible to backdrop, but doesn't affect specular or diffuse'?
    You can switch off "Affect Diffuse" and "Affect Specular" for the light.
    ciao
    Thomas
    Web: www.dieleinwandhelden.com
    I use two pieces of the three-piece application with mocap module.
  12. #57
    Aug 2016
    a place
    2,353
    exactly, you are illustrating my point about workflow and workarounds
  13. #58
    Set up your Environment Light once and clone it. Turn off "Affect Diffuse" and "Affect Specular" and "Visible to Camera" for the other light - done.
    If you set up your background in the Backdrop tab as usual you can change it for all lights together.
    ciao
    Thomas
  14. #59
    Aug 2016
    a place
    2,353
    nah. simple background. easy to understand, no workarounds
  15. #60
    Feb 2006
    england
    1,401
    or just use inverted sphere with backdrop with ignore all lights/shadows/rays, 100% illum, you can then change it independently too. you could even use lscript to make a menu button to add a sphere etc with just one click (I think people forget its incredible easy to record lscript macros to save time!)
