Results 1 to 9 of 9
Thread: Final Render animation
    Sep 2010
    Kuwait
    234
    Hi all:
    I wonder about the Final Render animation ,, in the LW 11 I find format like AVI or MP4 ,,
    but in LW 2019 ,, I don't know how can I save my animation ,, at least to which my final work ,,
    any idea to help thanks
    pass:sword OFF's Avatar
    Russia
    1,086
    you have to save the animation in a sequence of images. this will save you from wasting time if in the process of rendering lw crashes.
    Quote Originally Posted by nnabdu View Post
    Hi all:
    Always best to save out images.
    You can compile an .avi easily with a program such as VDub, which you can then load into After Effects/Vegas etc to save out as whatever movie format you need.
    Sep 2010
    Kuwait
    234
    Ok thanks all ,,
    Got it ,,
    Video Junkie Vong's Avatar
    Eagle Mountain, Utah
    320
    While it is always best to render out images, if you need to render straight to animation...
    On the Render Properties Panel > Output tab, remove the check from next to Final Render (Under Standard) and place a check next to Animation. Then at the bottom you can choose AVI, MOV, etc. and then below that you can click Encoding Options to more specifically narrow down the encoding (ie: MOV > H.264 or Animation codec).
    Curtis Rhoads
    Desktop: Win10 x64 | i7 3.4GHz | 32GB RAM | GeForce GTX970
    Laptop: Win10 x64 | i7 2.3GHz | 8GB RAM | GeForce GT650M
    Desktop: iMac | i7 3.5GHz | 8GB RAM | GeForce GTX 780M
    Quote Originally Posted by SpacialKatana View Post
    You can also use LW itself to compile animframes into an .AVI.
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    16,786
    The best you can do for free solutions.
    Download free Davinci Resolve and fusion, you would have decent tools for editing and color grading and doing som effects, light rays, masking, text effects etc..while Resolve is mostly aimed for the editing, fusion for the vfx type.
    16,786
    Quote Originally Posted by Vong View Post
    And that is the simplest way..with the risc for lightwave crashing etc..but for small fast test, itīs handy...however..for tests, use the codecs to compress it..but if you want to edit the clip in another software..and still do not want to compile it..as I and others recomend, set avi to uncompressed frames, will take up much harddrive memory though.
    Sep 2010
    Kuwait
    234
    Thanks all ,,, Great
