Results 1 to 15 of 20
Thread: Surface ID
    Surface ID
    What's the purpose of the Surface ID field on the Shading Model tab in the Surface Editor? Was this something that was someplace else in 2018,19?
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    Near Beaverton, OR
    1,869
    Haven't explored that yet.
    When you do an exr export, there's a Surface ID option which is quite handy in some compositing tasks. Can only assume it's related. Take a peak with the VPR Buffer options.
    The Big Apexx System:
    64GB DDR4-2666
    Still...Absolute Amateur scallahan1's Avatar
    Aug 2012
    Salem, NH
    215
    I peeked at the manual entry for that and it didn't mean a thing to me. Not that deep in surfacing myself. Can you say Amateur? LOL.
    https://docs.lightwave3d.com/lw2020/...dels-Photoreal
    Steve
    Yeah I save out Surface ID buffers all the time for comping.
    Quote Originally Posted by scallahan1 View Post
    Steve
    From the docs "SurfaceID - You can override the numeric identity of the current surface by changing the number in this field"
    Not sure why I'd want to do that.
    More research needed. Thanks.
    Tim Parsons
    Technical Designer
    Near Beaverton, OR
    1,869
    Ya, yet another "why isn't there a VISUAL of what the hell that means..." thing for BeeVee to get an entry for.
    64GB DDR4-2666
    Los Angeles
    7,276
    Just guessing here but maybe that's a way to assign a consistent fixed value to a surface ID? Sorry, I don't have LW open right now to check.
    I've used suface/object ID between LightWave and Fusion for years. For example, in my never-ending personal project B2, I use it to color correct a certain instanced tombstone that renders slightly brighter than the others so I don't notice a pattern so much in the distance.
    BTW, at work we've use Cryptomatte between Maya and Nuke or AE, instead of the standard surface/object ID, and it's pretty neat. I just enable some options and then Ctrl-Click in the image to add custom mattes for anything in the render whenever I need 'em, with proper aa edges...so simple.
    LightWave (via exrTrader) and Fusion also have this capability but I haven't tried Cryptomatte with these programs yet. Now that I'm thinking about it, I should try it today; Cryptomatte has been super convenient for me in other programs. More info: https://wiki.db-w.com/exrtrader201cryptomatte
    Aug 2016
    a place
    2,348
    yeah, I am surprised Cryptomatte is not part of LW.
    Pessac
    5,192
    Good job I happened to look at this thread. There is a link at the bottom of every wiki page for reporting a bug or a feature request for the documentation that you can use to open the Feedback Agent. Sending a report into the system has far more chance of resolution than talking about it on the forum...
    B
    LightWave 3D Trial Edition
    So you don’t know what it’s for either BeeVee?��
    Tim Parsons
    Technical Designer
    Near Beaverton, OR
    1,869
    <snicker>
    Très diplomatique!
    64GB DDR4-2666
    Pessac
    5,192
    I just write stuff up as they give it me. Sometimes I don't ask further questions, there's so much to write. That's why I need feature requests or bug reports (FRs for further explanation, BRs if something's wrong) to show me that more attention is needed in a specific area.
    B
    I hear ya!
    Tim Parsons
    Technical Designer
    ...From the docs "SurfaceID - You can override the numeric identity of the current surface by changing the number in this field"
    Late to the party...
    You can override the SurfaceID for multiple surfaces (give them the same ID) to get the same mask for all of them in the SurfaceID buffer (instead different for each).
    Perhaps we can find other uses for this.
    ciao
    Thomas
    Web: www.dieleinwandhelden.com
    I use two pieces of the three-piece application with mocap module.
    England
    6,004
    Yep, you can use whatever ID you want for any surface... so, if you require a mask that incorporates three different surfaces/materials, you can use the Surface ID override to include them all in the same buffer. Quite handy to be honest, if you need this sort of thing.
    Desk Work:
    Desk Home:
    Yep - I just saw your video lardbros, could be very handy at times.
    Tim Parsons
    Technical Designer
