Results 1 to 15 of 23
Thread: Rotating Nodal textures
    Near Beaverton, OR
    2,033
    I was assuming this was a pretty straightforward process but apparently it isn't. I've some nice PBR textures I'd like to rotate 90 deg. That's it. What's the trick in Nodes?
    The Big Apexx System:
    64GB
    Super Member omichon's Avatar
    Bordeaux, FR
    767
    Why not just rotate de UVs in Modeler ? or the texture map (before using it in LW) ?
    If you really want to do it with nodes, then Rotate node from DPKit is the way to go.
    www.oliviermichon.fr | 3D Animation, Motion Graphics and Broadcast Design.
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,201
    Do it like this. The input is in radians so 90 degrees is pi/2.
    Near Beaverton, OR
    2,033
    Quote Originally Posted by omichon View Post
    Well, I did cheat & did it that way but there's got to be a simple mathematical way.
    - - - Updated - - -
    Excellent. Thanks.
    64GB
    Near Beaverton, OR
    2,033
    Finally getting back to trying this and not having any luck. What am I missing?
    64GB
    May 2006
    France
    4,211
    Rotation is locked, not working in UV mapping mode.
    btw..
    Recently I fixed an issue in UV Mapping node from DP Kit 2018,
    was inverted, now it works properly,
    it can be used for a workaround,
    selecting the UV map in its panel,
    plug the oPos output in an oPos input of the Color Layer+ node (DP Kit)
    setup a layer image in planar Z mapping,
    then you can rotate it,
    but don't know if you can replace your U and V tile,
    by something like Scaling though.
    Denis.
    Near Beaverton, OR
    2,033
    Quote Originally Posted by dpont View Post
    btw..
    Denis.
    Thanks Denis. I'll give that a test later today.
    64GB
    Near Beaverton, OR
    2,033
    That did work as far as it goes & no wasn't able to do any tile scaling. But that's encouraging.
    I've run into this quite bit over time & seems odd that there isn't already a simple node for what would seem to be a very basic, common thing to want to do. I've got this texture & that UV...
    64GB
    May 2006
    France
    4,211
    I tried another way,
    I added an U & V inputs in the ReplaceSpot node from DP Filter (...works in Surfacing context)
    Image mapping must be set to ObjecUV (not UVmap),
    here U is plugged in V input and V in U input :
    Denis
    Near Beaverton, OR
    2,033
    I'll give a look today then. Thanks.
    Well, did get the update & replaced but this is what I'm seeing for that node:
    64GB
    May 2006
    France
    4,211
    The DP Filter 2018 update is 05/05/20 dated,
    readme file does mention this addition in the ReplaceSpot node
    (..and I verified the uploaded file on my site it is correct).
    Denis.
    Near Beaverton, OR
    2,033
    Denis.
    Very Strange. I'll take a deeper look tomorrow.
    64GB
    May 2006
    France
    4,211
    Another ObjectUV rotation:
    While the Image node must stay in ObjectUV Mapping mode,
    you can replace the current ObjectUV by another UVMap,
    using the Vertex UV Map node and its U & V outputs.
    Denis.
    Jun 2003
    Sweden
    4,201
    I was to quick. I forgot that you must change the image projection inside the image node to UV as well, not only plug in the uv slots on the node. I don't use LW that much anymore so I forgot. I also see that Denis has solved it for you.
    Bordeaux, FR
    767
    Setup described by Denis is what I use when having to tweak image placement on UVed object. Works great
