Page 5 of 7 FirstFirst ... 34567 LastLast
Results 61 to 75 of 102
Thread: LW2020 + Plugins
  1. #61
    ack ack Markc's Avatar
    1,535
    Try the flamethrower scene, that did all frames for me.
    Maybe a brand new scene built in 2020 with TFD will give a different result?
    It may not like old scenes pre 2020.
    Mac Pro (2010) OSX 10.13 RX580 Pulse LW2020
    (plugins: LWcad 2018, TFD 1427, Syflex 2018, StarPro 2020, ExrTrader 2020, Ubercam 2.0, RR Daz Mocap (not working), DP Light 2020)
  2. #62
    Aug 2017
    Slo
    123
    Flame thrower is OK.
  3. #63
    Aug 2017
    Slo
    123
    Weird things going on with TFD. In the beginning, when I first tried TFD in lw2020 I got black VPR and F9 (with legacy volumetric=true). When I try now I think the same TFD scenes are not black anymore. Occasionally I see the simulation window with some random colors right below the window frame (one bright dot right above the "Frame" on the image, sometimes there are many in a horizontal line) and "Stop" button is off the frame.
Name:	TFD sim window.png
ID:	147595   Click image for larger version.
Name:	TFD sim window2.png
  4. #64
    1,535
    I will have to try a new simulation.
    All my TFD scenes are simulated and cached from way back, so I just point to the cache and render.
  5. #65
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,612
    Re: Rhiggit issues - The data fields that the itemshapedata() lscript function returns have changed, going from 30 fields to 29. Hence, why comringencode() returns the error. I've let RH know about it, and the changes in how things are handled.
    I've run into this with my BuildNullObjects script, and I'm testing a fix. The main problem being is maintaining compatibility with the old version. I'll be testing mine today between 11.6.3, 2015, 2018, 2019, and 2020. Given the way the setting an item shape in lscript is done, it's a non-trivial task to fix.
    My Scripts for Lightwave
  6. #66
    Jun 2014
    Right here
    1,814
    Thanks for your analysis and contacting the dev!
    3rd Powers update:
    Compatibility with LightWave 2020
    We have released updates for all our products, which provide compatibility with LightWave 2020 by adding support for the changes.
  7. #67
    16,786
    I saw your post on jawset forums John.
    I have same issue with 10.13 and 1443.
    Thought I would give it a go in 2020, but it bombs out immediately.
    He seems to be concentrating on c4d......
    Looks like it unfortunately for lw users.
  8. #68
    1,869
    3rd Powers update:
    Ditto here as well for getting in touch with RH. Similar concerns re backward compatibility.
    I only have two of the 3d Powers tools & both are working just fine in 2020.
    The Big Apexx System:
    64GB DDR4-2666
  9. #69
    1,535
    RR Daz Mocap utility works, but is 'dog slow' in playback compared to 2015.....even on bounding box.
    DP Lights have been updated for 2020.....
    Thanks Denis
  10. #70
    1,535
    Is there any reason in LW render output, if you select multi-layer exr there are no options for color space or output.
    On a related note, rendering out of exrTrader, in Fusion I get an error in the console: 'no frame buffer specified as pixel data destination' (don't get this error with the native LW exr file).
  11. #71
    Stuttgart, Germany
    13,685
    Luckily I've just been reading the thread, otherwise I'd probably never know.
    Can you send me a sample file, even if it's an empty scene with the exrTrader settings? Also the version of Fusion would help.
    Cheers,
    Mike
  12. #72
    1,535
    Hey Mike thanks for quick response.
    It was user error on my part.
    I was loading exr then dragging to viewer before selecting any channels.
    No errors if a channel is selected........
    Fyi Fusion 9 Mac.
  13. #73
    Stuttgart, Germany
    13,685
    Dude, don't do this to me.
    Cheers,
    Mike
  14. #74
    1,535
    Mac users FYI:
    TFD 1443 seems to work in Mojave, didn't activate it, but menu branches all loaded.
    I found adding this version in HS no menu branches would load.
  15. #75
    Jul 2017
    Middle of nowhere
    256
    In Layout, OD Tools > 3D Coat App Link : seems to work. Tips: Be sure you connect paths, upon first use, to correct version of 3D Coat; be sure that you are opening up the correct version of 3D Coat when you are exporting from LW to 3DC.
