Thread: BGEO to LightWave
    Jun 2014
    Right here
    1,814
    BGEO to LightWave
    Hello
    I'm sharing some BGEO examples for who is interested (use with the LW2020 Partio Node).
    Low Particles (see example images below):
    https://drive.google.com/file/d/1QOC...ew?usp=sharing
    High Particles:
    https://drive.google.com/file/d/11zo...ew?usp=sharing
    Basic Fluid Sim:
    https://drive.google.com/file/d/1GIr...ew?usp=sharing
    I'll leave the download links for about 2 weeks.
    What I would be interested (and I have not been successful): Render the particles as volume (the 'To Volume' Node doesn't work for me or I don't know how to use it). I can render as mesh or as particles, but not as volume object.
    Also interesting would be good shading examples for the fluid by implementing the particle color somehow (from the Particle Info Node).
    May 2012
    Virginia
    545
    Thank you for sharing, Marander! I am looking forward to doing some experimentation with this when I get the chance.
    Jun 2014
    Right here
    1,814
    Welcome!
    I added another particle type: PTC (works fine in LW2020 too) - an animated vortex
    https://drive.google.com/file/d/1YGh...ew?usp=sharing
    Unfortunately, smoke and fire results in too large files due to the domain (multiple gigabytes), so I cannot upload examples like that.
    Nice, but how to convert this on the mesh ?
    2D/3D Specialist
    http://www.render-up.com
    Win10 64bit, Dual Xeon E5-2696 V2 @ OC 3,3 GHz per Core, 64GB RAM, 2 x GeForce GTX 1080 Ti
    Super Member Qexit's Avatar
    Warrington, UK
    1,204
    Quote Originally Posted by artzgo View Post
    You might find some useful tips towards the end of this video posted by DarkChief to help resolve a problem that exists with LW2020 and Deep Rising FX 3.0:
    https://www.youtube.com/watch?v=Ft5O...ature=youtu.be
    At just after 17:00 in he uses the Partio Node to link to the data generated by Deep Rising
    Kevin F Stubbs
    Jun 2014
    Right here
    1,814
    I'm not sure I understand? You mean how to convert the imported particles into a volume mesh?
    I found 3 ways to use / render them in LW.
    1) Render as Signed Distance Field Volume. From Particle --> Grid --> Mesh Volume, improve quality by using the smoothing options
    2) Particles. Directly render the Particle system. Use the imported attributes (color, age etc.) if needed.
    3) Volume. Create a Volume object. Create a separate Null with the VDB nodes and reference the Volume object to that Null (described in the LW documentation). Use the imported attributes (color, age etc.) if needed.
    2D/3D Specialist
