Thread: NDI Virtual Input Not Loading
    Apr 2020
    Rochester, NY
    2
    Per title, Virtual Input is not loading (no icon in the system tray). Have tried reinstalling Toolkit, have tried launching it manually, no luck. Anyone have this issue or any ideas how to troubleshoot?
    19,919
    It's not, by any chance, in the 'hidden icons' shown only when you click the caret gadget at right?
    I just tried and the boarder does turn blue once you connect the camera to a destination.
    Apr 2020
    Rochester, NY
    2
    Smile Solved
    I went into Task Manager and found the process "NDI", which was running. I used that as a path to get to the application properties. I set it to run as Administrator (it wasnt before) and ended the process. Then relaunched NDI Virtual Cam. Windows asked me if I wanted to run as administrator, I said yes, and presto! - NDI appeared in the task bar. Selected the NDI source and its working perfectly now!
    May 2020
    Germany
    2
    Hi
    if I start virtual input, I get a command window "windows\system32\Wbem\wmic.exe
    after about 20 second, a message pops up
    "Windows update needed"
    "Microsoft security Advisory 3033929 is requered for this application"
    If I press OK, I was rederectided to a microsoft website to install 3033929
    After donwload, the install process writes that the patch was already installed
    On the win7 home all upates are installed
    how can I get "Virtual input" working?
    this problem is on two other win7 computers also
