I want to create a macro who does following:
After created a new replay clip in DDR1 I want to select the last recorded clip and be able to play it manual when its time for the replay. After its played I want to selected the last clip again and then use another macro (I have created one that copy the clip to another playlist in DDR 2 for highlights) I donīt want my first macro to copy the clip, because I want to sort the clip manually to different playlists (playlist 1 for goals, playlist 2 for "good shots" and so on...)
My problem now is basically that I cant figure out what shortcut I should use to select the last clip in DDR.
