Thread: NDI 4.5 and Premiere recording
    Jun 2006
    Chicago, IL
    595
    So, with the release today this was noted:
    Unlimited IP recording, with Adobe Premiere plugins both for real-time NDI and working with time-locked ISO recording across multiple streams.
    How does this work? I don't see any difference in the capture functionality in Premiere. How do I access that plug in? Do I attempt to import a file as it's recording on a device, across the network?
    Thanks in advance for any insight into this.
    Fritz Golman
    Jun 2006
    Chicago, IL
    595
    Anyone?
    The IP Unlmited recording is that using NDI you can record as much content as possible, between using NDI Studio Monitor, TriCaster or the command line NDI recording tool. Then take all of that footage into Premiere for editing. If you setup NTP between all of the systems, then all of the NDI recordings will have matching timecode to make it easy for multicam editing.
    Jun 2006
    Chicago, IL
    595
    Gotcha.
    Was actually quite a bit more straightforward than the marketing prose led me to believe!
    Thanks Kane!
    Stay healthy!
    Fritz
    Jun 2012
    Europe
    257
    my feeling is this is exactly the same feature released with NDI4, don't see any difference .....
