Results 1 to 15 of 15
Thread: animation help
    May 2007
    turkey/ istanbul
    14
    animation help
    how can make like this in lightwave anyone can help me please ?
    https://www.youtube.com/watch?v=2blEdHrmfbQ
    Near Beaverton, OR
    1,784
    I can't find the demo scene but there was one with the LW content demonstrating transferring of Parenting between items. I think that's basically what's being used with your cube.
    The Big Apexx System:
    64GB DDR4-2666
    Try this test scene: Cube_Roll_Content.zip
    It is using the Parenter plugin, under the Cube's motion options. It uses nulls to parent to rotate and flip the cube along. Read up on it in the manual: https://docs.lightwave3d.com/lw2019/...ifier/parenter
    There's probably some tutorials on youtube also.
    Here is another slightly different method:
    Wuerfel.zip
    "Control" controls the cube. A 360° rotation on the bank axis moves the cube. This allows you to easily animate direction and speed. The bank rotation controls the Cyclist Motion Modifier of the Cube object and the Null. With "Startposition" you can modify the cube starting position.
    If the cube should not be 1m x 1m x 1m you have to adjust the animation of the zero object and the Cube object. The Cyclist Motion Modifier is set for 100 rollovers. If you want the cube to roll over more often you have to adjust the Cyclist Motion Modifier.
    ciao
    Thomas
    p.s.: there is a LW 95 and a LW 2018 Version.
    Web: www.dieleinwandhelden.com
    I use two pieces of the three-piece application with mocap module.
    Jan 2005
    Colorado Springs
    1,855
    It may not be what you're after, but you could use Bullet as well, using a hidden "poker" object to push the cube along. A roughed out sample scene is attached:
ID:	147115 Click image for larger version.
ID:	147116 Click image for larger version.
ID:	147117 Click image for larger version.
ID:	147119 Click image for larger version.
ID:	147120 Click image for larger version.
    MOV file: Bullet_RollingBox_HiddenPoker.mov
    Persepective view showing hidden "poker": Bullet_RollingBox_HiddenPoker_Perspective.mov
    Here's the base setup:
    where the Poker object has "Unseen by Camera", rays, etc. set in the Render tab. The Friction is set to 100% on both the cube and the floor so the cube rolls rather than sliding along under the impetus of the poker.
    mTp
    Attached Files Attached Files
    Last edited by MonroePoteet; 03-23-2020 at 10:48 PM. Reason: Friction on cube and floor
    Near Beaverton, OR
    1,784
    Quote Originally Posted by MonroePoteet View Post
    mTp
    For some reason that just strikes me as hilarious. "Go on! Git! Git! Move it!"
    I used a a similar bullet technique (probably suggested by you) for BB2 as RebelHill sort of glossed over animating him in his tutorial.
    64GB DDR4-2666
    Jan 2005
    Colorado Springs
    1,855
    Yes, it was fun setting it up. Poke the box, wait for it to settle, poke it again. "Now GIT!"
    BB2? - sorry missed the reference.
    mTp
    Near Beaverton, OR
    1,784
    The droid from one of the Star Wars...
    In Rebel Hill's LSR series, he uses a free model to demonstrate surfacing with the Node system. RH skipped over the actual animation part though and someone suggested using Bullet. So, he has a Bullet sphere pushing from inside the lower body sphere. I worked but not the easiest way to animate certainly.
    64GB DDR4-2666
    Near Beaverton, OR
    1,784
    My error. It's BB-8.
    I never saw this one, or any after for that matter. I'm probably in violation of some law but so it goes.
    64GB DDR4-2666
    Dec 2009
    London, England, UK
    1,111
    Blog Entries
    18
    No sir. The crime is that they were made in the first place.
    Near Beaverton, OR
    1,784
    Quote Originally Posted by Shabazzy View Post
    Well, once Di$ney got involved, sounds like things went a bit off the rails. George knew what he was doing by taking the money & skedaddling. But it's not just them unfortunately; it's systemic. My movie viewing, not just going, has dwindled considerably over the years; largely due to them becoming everything except story driven or original. The pendulum will eventually swing, but it's going to take quite some time I suspect.
    64GB DDR4-2666
    Jan 2005
    Colorado Springs
    1,855
    Oh, right. For that "roller ball" kind of droid, I'd use a Bullet Forcefield rather than the poker approach, although it shows up what I consider to be a severe limitation of Bullet: the lack of FX "groups" that were available in the classic LW FX implementation which allowed a Wind (i.e. Forcefield) to only influence some subset of Items in the scene. Sample scene attached.
ID:	147245 Click image for larger version.
ID:	147246 Click image for larger version.
ID:	147248 Click image for larger version.
ID:	147249 Click image for larger version.
    MOV file: Bullet_BB-8_StarWarsDroid.mov
    The sample scene as uploaded requires the DPKit ParticleInfo node to leave the trail in the sand, since the native ParticleInfo node doesn't allow specification of the input FX Emitter left by the droid which then adds a Bump map to the sand texture.
    The head of the droid is controlled by a Nodal Motion graph, which places it in Y above the Bullet-moved Body, and the rotation angle is controlled by the Forcefield's Heading with a textured World-Coordinate Pitch to "bobble it about".
    mTp
    P.S. I didn't like any of the SW prequel / postquels, but I thought Rogue One was OK - just my opinion, though!
    cute!   
    mighty cool, tried that using HardFX soem time back, but couldn't quite make it work...
    Thank You!  
    Near Beaverton, OR
    1,784
    mTp
    Maybe I'll check out that one then.
    I've saved this scene off & will certainly play around & check out what you came up with.
    64GB DDR4-2666
