Thread: Advanced Edition 3 no longer supports iVGA - Need help
    Dec 2012
    London
    21
    We recently upgraded out Tricaster 8000 to the latest Advanced Edition 3 firmware and we lost ability to display our Easyworship via ivga to traicaster.
    I have read about the NDI solution and installed it on the desktop and setup everything but I have facing a challenge with this new system.
    The laptop main screen is captured on Tricaster as a feed but no where to force it to display the secondary screen which is where we project our scriptures to external monitors.
    The old ivga had a setting that allows you to select which screen but this new one does not have such option hence we are stuck.
    Anyone able to assist.
    19,644
    Assuming you're using Scan Converter, it is not necessary to select one or the other screen in the app. Instead, both screens are supplied to the network and you select the one you want to connect to on the TriCaster.
    Unless two different physical graphics cards are being used. NDI Scan Converter will only offer the 'primary' GPU.
    Otherwise, there are other Scan Converter 'like' tools you can use. OBS Studio with the NDI plug-in or vMix Desktop Capture are other solutions. They don't offer the same performance as NDI Scan Converter, but they should work on multi-GPU systems.
    Dec 2012
    London
    21
    Hi guys sorry I didn't get any notification of comments but just seen them now. I will review the scan converter and see if its the one I installed and give it a try.
    @kanep you know what I never actually checked if we have more than one physical adapter so would check that also. thanks
